Hello SAU.
This is my first post.
Just starting to get the skyline bug now. I currently own a Version 1 Subaru Impreza Wrx Sti in Silver and i will be moving out to North Perth in December.
I will be hoping to purchase a Skyline either from Perth or Imported. Though if i cant find one then i will probably stick to Scoobies.
Is there any websites for Jap Importers around Perth?
I am after a r34 GT T. Though i am not to sure if these are availible in Australia.
Can anybody help?
Mad Scot
All the way from the Isle of Man (TT Races)
Plenty of time and the cost of the R34 GT-T's will come down a bit yet by December.
TT races are mad aren't they??
Drove the course the last time I was there and still can't work out how Tony pond managed that 100mph lap .
Cheers
ken
  • 3 weeks later...
I recently got my skyline through imports101 and from my experience i can definately recommend them... the only problem with importing a car is it requires lots of patience. (and obviously u cant try b4 u buy).. Good aftersale support from imports101 as well, not just sell and forget.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
