Most of the cuts had aftermarket suspension, it is included in the price. THe SW20 MR2GT Tein sus is DA also - forgot to put in original post.
Ken
  • Replies 91
what can I say ken, you do get the good sh1t. :)
guys, Ken is a good honest trader and wont f**k you around.
On that note, can you pm me a price on the BNR32 ARC airbox?
Cheers mate, and best of luck with the rest of the bits.
what can I say ken, you do get the good sh1t. :P
Thanks Richard, man how heavy was your bag going home? I got pulled up at check in about weight - they werent happy, but I did get away with it.
Pm sent
Cheers,
Ken
I'll second that - and i aint met Ken yet, even after a few months of business over the phone lol :P
David
You seperating parts of the GTR front cut? could I get the lights, grill, headunit mounting bits and plugs and the 3 dials?
Only have the centre dial for you, what would you like to pay? Pm me please.
Hey mate you don't have a RB25 throttle body laying around do ya?
No I dont, but you could try your local supplier PRIMO, dont know if he is in the country at the moment or not?
Give Oden a call at Bundy Reshine.
Cheers,
Ken
Tell him I sent you.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
