What do u guyz think?
But if you've got the flex sensor whats the issue? You just run what you can get your hands on. I can't see any reason not to run e85 if it's relatively local to where you live. -
By PotatoCake · Posted
Exhaust end of this month, and then tune after that whenever there is availability. Still tossing up between a pure 98 tune or a flex 98/e85 combo. The (lack of) milage in e85 isnt great. Start to get anxiety if i go for a long drive and there arent any united servo's nearby -
I mean I can be OCD'y but this is really over the top. At that point why not just run a full wideband fuel controller? Especially if you run 3 widebands. The system works pretty well, which is trimming low load stuff to be within a few percent of the base map. Pre-engine _change_ the base map was only 1-2% off, depending on ambient temp, elevation, etc. Under load the LS is really very straightforward to tune, enough that a wideband closed loop would be overkill. If I really cared (and I hope I don't) I can always just go back to the MAF system the car actually came with. Which does all those nice calculations for me (temp, altitude, etc), now that you can buy 102mm MAF's that do not cause restrictions.
Good afternoon Team , just a quick update on performance mods Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO - Cat Back RV37 Skyline 400R (SKYLINE) | FUJITSUBO - Front Pipe AMS - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes - to be installed in May
I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
