Pinging=detonation
It's caused when the timing (fuel/air) is too far advanced...it creates an un-even burn in the cylinder, and it can cause pitting on the surface of the pistons.
If you want to advance the timing, make sure you use PULP to get the most out of it.
There's no need to put the car on a dyno to advance the timing, go buy a timing light and do it yourself.... check what it's set at, advance it a few degrees, go for a drive.. if it doesn't ping, advance it a bit more...
...but as megs said, if it starts to ping, back it off. :cheers:
https://www.sau.com.au/forums/topic/74293-dyno-tune/#findComment-1369381
If you're still running the factory ecu, there is no point to a dyno tune.
The ecu constantly tunes itself.
Your are so far off SKY031. The only time a car tunes itselfis in closed loop mode. When you reach certain parameters MAP/RPM you venture into a place called Open Loop this is where most hoons drive.
https://www.sau.com.au/forums/topic/74293-dyno-tune/#findComment-1383964
to rob82 you are 50% correct in your statement..
the car does not tune the afr in open loop but it does muck around with the timing a little..
ie. if the car is detonating it will pull timing a little..
thats why the cars go that little bit harder after you have had the battery disconected for a bit to clear all of the long term trims..
also it would be fair to say that if you were getting the car dyno tuned you have a MAF modifier on the car.. all skylines run very ritch up high in the rpm and a bit can be gained by leaning it off..
just my $0.02
https://www.sau.com.au/forums/topic/74293-dyno-tune/#findComment-1384307
Boston if you've ever seen the primary ignigtion map (hi or low octane) you would know that the knock sensor will only pull timing out of the low rpm high Load part of the map. Nissan have obviously not done proper reaserch into constant knock sensor operatioin throughout the rev range. This is why in my opinion all nissans are rich as in standard form. Thats why nissans make great power NA or Turbo. There is so much fuel to take out and lots of timing to put in.
https://www.sau.com.au/forums/topic/74293-dyno-tune/#findComment-1384954
I'm not so sure it only pulls out timing from the low rpm high load parts of the map.
With the stock r32 ecu it was pulling timing out (10degree's) from as high as 4500rpm. I am 99% sure the knock sensor stops pulling timing out over 5000rpm as that is where all the timing was thrown back in and it would ping once again.
This was monitored via consult.
https://www.sau.com.au/forums/topic/74293-dyno-tune/#findComment-1385150
The nissan consult cant tell you how much knock retard the ECU is pulling out or at least ours cant. Where you just watching the ignition timing. I know within the map that a value greater than 80 HEX enables the knock sensor to function and pull timing out, if you look at the map you will see. Not sure what RPM it stops working but i'm pretty sure its well before 4500 say 2500 rpm.
https://www.sau.com.au/forums/topic/74293-dyno-tune/#findComment-1385264
Are there benefits to getting your car tuned on a dyno if is an NA. I read that the turbo boys get heaps of power just by getting a run and tune. HOw much could you get out of an NA?
sorry if I sound a little uppety here Kor, but.....
..................if nothing else, regardless of a frickin' ECU upgrade or not or this or that or whatever......a dyno READ-OUT can give you the state of your car's power! (therefore health??)........................
by ......USING THE METHOD OF COMPARISON!! (between your car prior to 'fiddling' and post your 'fiddling' and to other cars (regardless of type!) of similar configuration. All this Just by looking at the graph they supply you.
and......how else can you get the car to phenominal speeds and under full load and have a tech/mechanic with his head still under the bonnet?
Dyno = a reporting tool! ...nothing else. Tuning is an entirely different entity.
The process just sort of happens at the same time.
It is the best way to diagnose and see if there are positive or negative responses to what the tech is trying to do for the car.
So yes!! Massive happy happy joy joys can be achieved by tuning a car via the dyno 'method'........just the pricing stinks to the standard car driver.
ahh.. that feels better.....have a great week K'!!
ps...just got my 33 (dyno tested) by MK Auto in Moorabbin....173.4rkw, with my crummy airinx pod filter.......185 with the new K&N!!!!!! No tuning required!!!
https://www.sau.com.au/forums/topic/74293-dyno-tune/#findComment-1385385
CAS Ignition timing was 5degree's.
133rwkw
The stock rb20det turbo's wastegate was wired all the way open.
Boost begins around 4000rpm the consult stated 28degree's ignition timing, the dip occured and the usual slight puff of smoke (detonation), looking down at the consult you can see the ignition timing drop by 10degree's and fuel richen up.
Connecting the wastegate so it made boost early had massive flat spots everywhere.
Point being the stock ecu definitely does pull timing at mid/higher rpm.
I've heard of this occuring often. Possibly reinforcing that the ecu does indeed have influence of the ign. timing at the higher rpms.
http://www.skylinesaustralia.com/forums/sh...+sensor+5000rpm
https://www.sau.com.au/forums/topic/74293-dyno-tune/#findComment-1385529
Good point however if the dyno sheet you showed me was in 4th gear then at about 74km/hr (where the dip occurs) the rb20det would be doing about 2500-3000rpm?? It would have seen quite a substantial knock and pulled timing out. The extent at which returns from a knock event is determined by the decay factor thats why it dosen't start making power again till 86km/hr ie. it takes quite a substantial time to recovery from a knock event and the rate of acceleration of the engine is much to fast.
https://www.sau.com.au/forums/topic/74293-dyno-tune/#findComment-1385799
It was an RB30DET running the stock RB20DET turbo, the turbo had its wastegate wired all the way open to prevent boost being made, even though it was wired open it still managed to make boost over 4000rpm, which is where power started to dip and carry on badly.
With the correct cas timing of 15degree's & the wastegate hooked up the dyno run looked like a roller coaster all the way from idle.
The rb30det with the rb20det turbo makes all of its boost on the dyno by 1700rpm IF the motor is loaded up from 1100rpm.
Discussion is good. ;) From what I experienced with my RB20DET ecu was that it did indeed pull timing and dip up to 4500rpm. Over 4500rpm it didn't appear to pull timing as I could see it was detonating yet the ecu wasn't pulling timing.
The dyno run I attached was the final cleanest dyno run, from memory it was actually dipping at 3500rpm. It was only 1 dip unlike the other runs that dipped from basically idle right up until ~4500rpm prior to pulling cas timing back to 5degree's.
https://www.sau.com.au/forums/topic/74293-dyno-tune/#findComment-1385815
Had another look at my GTR timing map, 4000 is the standard limit for the knock sensor to operate. So if it had a large knock at say 3800 it may not recover fully, as in pulling out 0 degree's timing until say 4500. Still hacking the ECU for the knock recovery rate (if there is one). I know there is a max knock limit. I might be thinking that the MEC-R(**** forgot number 215-maybe) is actually smarter than what it actually is, it is over 15 years old after all. Where do you work cubes?
https://www.sau.com.au/forums/topic/74293-dyno-tune/#findComment-1389552
So does this all mean that you can or can't tune an NA with no ecu?
hey davor, hows things mate?
this thread is all over the shop whith things i don't understand (and haven't really read), but back to dynoing...
when i did this with mine, they firstly put the car on the dyno and warmed up the tyres.
then the tuner went through the gears for a few mins to check the condition of the gearbox.
then he gave it a base power run.
then he jumped out and played around with the timing
then he gave it another power run
then he played with boost a little (i know you can't do this with your car)
all up with interruptions my car was on the dyno for about 2.5hours and i paid $110 for an hours worth of dyno time :(
so back to your question...
can they 'tune' the car?
to me, 'tune' means change the ignition maps or AFRs, and no they cannot do this unless you have some sort of aftermarket ECU or interceptor device
but you can get them to tweak the timing a bit, assess the health of your engine and gearbox, and give you a nice printout of your power! its a great way to tell if your car is in good condition or on its last legs...
if you really want a bit of a tune you can get an SAFC (do a search if you don't know what it is) and they could play around with AFRs a bit
good luck!
Warren.
https://www.sau.com.au/forums/topic/74293-dyno-tune/#findComment-1389668
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
