Ive got a near new GT30 for sale. Turbo has done about 3000kms since new. 0.7A/R front, 0.86 A/R rear. Looks brand new. $1500 firm. Its externally wastegated too.
Shaun
0414972596
Its a T3 flange. It will fit on the standard RB20/25 manifold, however, you need to weld a spacer to the manifold so that the comp cover clears the block. Not a huge job, i got GCG in Sydney to do mine. It would be perfect for an R33 engine id say. Yes, i have receipts; not sure about warranty, i didnt ask at time of purchase. It is quite new though.
Nismoid, Im not sure what you mean by the OLDER style TO4 wheel?? As this turbo is only about 8 months old, and is an off the shelf Garrett item i would have thought its pretty new stuff. I was of the opinion that TO4's were old tech truck stuff, but im not an expert, so best to speak to GCG for that sort of stuff. I thought the 0.82 was 550hp and the 1.06 was 600hp.
Shaun.
Nismoid, you have a PM. Please reply.
nice turbo indeed.
Is this a 500 or a 550hp version dude?
As it has the older t04 wheel i think it then makes it in the 500 range if i recall correctly.
I had exactly the same turbo on my rb20, made 200kw atw easily without pushing all that hard. The big front cover keeps the heat down and makes that awesome hollow choof sound. The front wheel is capable of pushing 550hp worth of air, but its the core design that sets these apart from the old t04's, mine would be still spinning 25 -30 sec's after switching car off! A very responsive (for its size) and durable turbo and at $1500 sounds like an awesome investment for r32 or r33, of r34 for that matter. Wish I could get em that price when I bought mine. Oh Yeah and I have a modified vg30 (to suit gt30) housing with integral w/ gate available for those who may want to put on stock manifold, also a split dump pipe stainless. see my thread.
Yeah, it does take a while to spin down due to the ball bearing core!
Please take note that these Garrett GT30 Ball Bearing Turbos do not have the "older style" TO4 wheels in them. They do, however, have a TO4s (the addition of the "S") trim compressor wheel in them which is the current model GT Spec super duper compressor wheel.
Please dont be fooled by the TO4 thing and its old technology connotations, as this is not the case at all.
And the above bloke is right; it is an excellent price considering the lack of use this thing has had.
Shaun.
Hi Shaun,
Is it the Exhaust A/R or the Inlet A/R that dictates HP rating? I'm very interested but not sure if it will do the job on my new rb30det. I am aiming for a little over 300rwkw. Is this turbo big enough for this target?
cheers
Steve
QQQQ, you have PM. Im sure this turbo will suit your needs and provide excellent response.
All the specs of the GT30 series turbos are provided on the GCG website under technical info and specifications of the GT25 - GT35 range.
Youll also find that these things are $2650 new.
Assuming you mean low mount on the standard manifold, you need the following:
• A spacer welded on the manifold flange so that the comp cover clears the block.
• A screemer pipe welded into the manifold so that an external wastegate can be used.
• New water and oil lines.
• New dump pipe
• New induction piping to suit the 4inch bell mouth
• Modified intercooler piping to the turbo.
It worked well on my RB20, but if i had my time over again, id just go high mount. just my opinion. The turbo is sold anyway........finally!
  • 3 weeks later...
Hi Shaun
Im considering getting a GT30R or a Garrett T3/T4 for my RB20 and just wondering what rev range the GT30 would start getting boost at when you had it on your car?
Ive heard some people say it will not get positive boost until at least 5000rpm?
Is this true?
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
