I came accross this gts-t on the car sales website and cant help but think how familiar it looks.
the interior the body work and the front mount allong with the mirrors and paint job all except that there is no wing.
It looks like an ex autosalon car and magazine car.
http://www.carsales.com.au/pls/carsales/!c...rch_distance=25
https://www.sau.com.au/forums/topic/74339-ive-seen-this-car-b4/
it was in hpi No. 31, cover car...had loads of mods. the interior pictures and engine bay pic are lifted straight out of the magazine, but the exterior has different rims and no wing.
it has had a fully rebuilt engine with loads of apexi parts, with an apexi AX 53B70-P25 ball bearing turbo. 268rwkw.
the car was also in WA when it was published.
are they the same 2 cars....hard to tell....but i'd be staying away from it just in case. if it still had the mods, u'd think he'd list them...
cheers
Linton
