R32 GTR... HELP ME!!!!!!!!!!!
Power stearing GONE. Driving along, heard some funny missing noise, sounded like i was in a WRX for a second, then it was all good again. Pull up, realise there is no power stearing. Remove the shattered belt remains.
Keep driving for a bit without power steering, suddenly, no more spool! AT ALL!!!!!
Nothing, turbos are NOT spooling! Engine sounds fine, cooler pipes seem in tact.
Just got car off defect, now this...
You guys go right ahead and write back, I'm going to go cry somewhere... :Bang:
F#@KING PIECE OF S#&T NISSAN F#@KING SKY_F#@kING_LINE... I hate it! I hate it!!!! :)
https://www.sau.com.au/forums/topic/74341-power-steering-gone-then-no-spool/
I don't know but I don't believe in coincidence. Could the ecu detect the power steering loss
and go into a limp home mode?
Thanx sooo much for writing back.
I was hoping the same thing. Two things that back our theory up
#no sh#t loads of smoke
#drives really well with no strange noises... just plain doesn't get over zero on boost gauge and feels like this is the case.
doesn't reset after turning car off tho... maybe i have to fix power steer first...
how would it achieve such a limit? just like a rev limit, but using the air passing thru the AFM to say stop right there buster
:: EDIT
i didnt quite see you mention GTR.. so my response to your no spooling of maybe your exhaust wheel went down your pipe would seem to be quite wrong since you have TWO turbos and its unlikely they both went..
pardon me.. ill be on my way..
shaun.
OK OK, now this has elevated status to critical.
Replaced the power steering pumps belt today and power steering is back better than ever....
NO TURBO'S!!! NONE. Car is very drivable, sounds a little weird when it would normally be boosting, but besides that, drives pretty normal.
Am going over to reset ECU now... been checking for signs of leak from cooler piping... nothin'
Am a nervous kid. :)
Reset the ECU. No change.
It's like the turbos aren't even there. They make no attempt to spool. There is no noise at all from them. There is possibly more noise going on under the tappet cover than normal. Thats the only difference in noise.
HELP HELP!
Some of you guys must have some idea...
i had a similar problem, no spool after a back fire. found out the new cooler i had fitted on the left hand side the cooler pipe had blown of but the pipe was still inside the hose so was hard to locate boost leak. it worked out that there was no bead welded onto cooler pipe to stop hose clamp slipping of. my car lost all boost and also sounded like a wrx just before the hose came off completly. before this problem was detected i had the induction piping to turbo of to check that turbo was still spinning when engine was idleing, which it was because i thought i had blown exhaust wheel off!! hope this helps you.
This may seem silly but are you actually driving the car?
My car won't boost without load, so free revving it on the spot won't go over 0 psi.... this is my first turbo car and when it happened to me I freaked out too heh.
Good luck, I hope this it :)
Haha, yes. I noticed it while driving.
Although boost doesn't go much over 0psi with no load, you can normally here the turbos, but at the moment NOTHING.
I was thinking maybe actuators were stuck open, so tryed to drive it up and down the street a bit on varying loads to maybe unstick them (foolish plan I know). It would be strange they would both go at once.
I reckon its gotta be that too hey. Just be screwed if I can find it.
I was certain it was the top pipe off the inlet of the turbos. cause I had just taken it off to attend to the power steering pump. So when it went, I was like, I know EXACTLY what that is... then I pulled over, and its fine....
I guess I should just go check ALL of the pipe work... it would be weird if one blew off besides the one I was messing with....
yeah, thats the thing. I was actually taking it for a test drive with the belt off, to see if it was ok to drive with out power steering. so when it went, the belt was already out of the car, i wasn't going nuts... everything was normal.
I have just checked the pipes again... its hopeless.... nothing...
thanx heaps for the ideas guys... i'm just useless.... *crys*
Don't know how hard it is on the Gtr but you may have to take the dump pipe/s off to see if you still have exhaust wheels on the end of your turbos.
You would think you would hear a boost leak if some of the plumbing got taken out by the belt but if everything looks right then I'd be thinking turbos.
yeah, i was thinking it might be somewhere there as i can't see anything wrong with the actual intercooler piping...
but i couldn't get to the bov pipework... its on the passenger side down low isn't it? i can't even work out where the bov is...
how do i get to it to check it?? looks like i'll have to take off the front bar...
On a related note, what should one replace the hoses to the BOVs, actuators, etc with? Silicon hose, braided lines (bit OTT?), or just go with new stock jobbies? I'm tempted by the silicon hose as there seems to be a lot of it around at the moment.
LW.
Would have to be a pretty big leak for it to make 0psi on full load.. and you would certainly hear it.
I have had intercooler pipe leaks on GTR's before, even small ones made a large sound but I only lost a small amount of boost. The turbo's just worked harder. :(
You would also be very unlucky for both turbo's to fail at the same time.. very!
You must have a whole intercooler pipe off.. I would take the front bar off and have a really good look.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
