hey all
i've been a fan of skylines for a long time and i'm thinking of finally purchasing one, i've found a 1996 Series 2 GTS-T Auto with approx 61,000k's on it with 12 months rego for $19k... its stock except for exhaust and pod filter...
just wondering is this a good deal? and also will i be able to have as much "fun" in an auto as with a manual... i've pretty much always driven auto's and don't think i can be bothered going to manual, but if its going to be a huge difference with say.. instant power resulting in loss of traction (or the other way around) hehe
in other words i wanna be able to possibly get into drifting and every now and again smoke the rears :) the only reason i'm asking such questions is that i went from a car that i could have a hell of a lot of fun with to a car that is as slow as a wet weak when you plant it (despite being a 2000 model vehicle with a V6)...
so yeah, also if there are any things i should look out for with R33's, please let me know. i've always owned commodores, so a skyline is a bit of a change for me and i'm trying to learn as much as possible before making the purchase
If you've been driving autos for a while now (3 or so years whatever) you'll find picking up a manual to be simple. My mate was an auto driver from the start (although he got his manual license) and just bought an S15. It took him a few weeks and now he's fine with it.
Manuals ARE more fun. So if you're buying a car for FUN, buy a manual.
man i thought i would never be able to drive a manual till i had like 2 driving lessons then i got it now im smoking the tires easily lol go for manual heaps more fun and no automatic lag plus auto is more strain on the engine or go for a R32 manual not as much of a whale.
hey all
in other words i wanna be able to possibly get into drifting and every now and again smoke the rears :( the only reason i'm asking such questions is that i went from a car that i could have a hell of a lot of fun with to a car that is as slow as a wet weak when you plant it (despite being a 2000 model vehicle with a V6)...
sounds like a nice car - low k's, decent price for a S2
auto isn't as bad others will have you think...
best of luck with the decision :)
Warren.
My first car was an auto non-turbo VL.. It was a good first car, but after just 10mnths driving it i sold it and moved on. Not a fun car to drive as there just wasn't enough power and got sick of the auto too..
Not long before i got my manual r33, a mate bought a 96 s2 auto for about 19k on road..
The auto is good if you just wana cruise but you wont be happy just cruising all the time once you get the car and thats where manual is much more fun..
I drove his auto just last week and the tranny seemed really tight! but it made me kinda sleepy...
Another thing, auto's are generally cheaper...
End of the day, you have to drive both and decide for yourself...
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
