hey guys,
first box is made....in my car....needs some further touching up, but overall, im happy with it. looks good... will make up the radiator panel tonight and chuck it on so you guys can see it.
after looking at the engine bay, a similar box around the washer bottle and fuse box would look good. might look into this if anyones interested.
will be down in newy tomorrow. anyone wanna meet up at bar beach...bit after lunch. someone else post up a time...
prices are confirmed
$50 for radiator panel
$100 for airbox.
will take orders tomorrow or email me at [email protected] with your address and whether you have standard i/c piping or a pipe going over the radiator.
cheers guys
Linton
https://www.sau.com.au/forums/topic/74364-newy-guysupdate-on-airboxes/
yeh i was down there....was gonna pull up, but there were no parks...i was already tired so i left for home. next time though...ill probs be down this weekend...will let you's know.
doodz...i (Garage Debris) am making up some aluminium airboxes and radiator panels. same as UAS items although will be alot cheaper and better.... i have a UAS one in my 33 and not happy with it....it does nothing except put a box around the filter.
havent got prices yet either, will sort that out after 1st one is made.
cheers
Linton
let me know if you guys are gunna be down at the foreshore this weekend. I might come down for a bit.
You should see my car now Linton, with my newly aquired drift damage the front bar is starting to look as ratty as yours :headbang:
And with the airboxes, there's no real rush.
My mate with the 180 says he still might want one, and I discovered he has a piece of thin checker plate bent around where his box would go, would be perfect for getting the size when you get time.
:P
hahaha, GO DRIFT DAMAGE!!!!!!!!! :P what do you mean as ratty as mine?? hahaha....go rattiness!!! i love it!!!
i got pissed off with the wing late one night/early one morning and ended up cracking it and denting the bootlid... its cemented on there, not coming off. gonna have to be good damage to beat that.
ill let you know if im gonna be there.
also, any questions...im on msn.. [email protected]
cheers
Linton
HOLY SHITBALLS!!!!!!!!!!!!!!! hahaha, damn ian, thats rough. panel damage is one thing...but once you hit a suspension component....it goes to the next level...
id get my car towed before i ever put the space saver on too. haha, i love it, thats awesome.
Haha....
I drove around for two days like that too!
Luckily its only 5 mins to work though.
Got the rim fixed, and it looks ****ing sweet! I love not having chromies!
Fixed the control arm today too, now I just gotta get a re-alignment, and get out the fiberglass repair kit and she'll be sweet :headspin:
ok guys....ive had a breakthrough....i got the airbox out of my car...things are all go. getting aluminium on thursday...gonna drill into em and get heaps done. got some guys that have defects to clear so they will be first in line...jeez im a nice guy.
looking at around $100 for the boxes.... will also be further modifying these down the line...which will equal a price rise, but more on that later.
not sure if a 33 box will fit in a 32...but we'll have a look.
cheers
Linton
any chance of pics?
i was going to make one for my pod when it arrives from japan, but if i become very lazy i might just buy one off you :D
does it provide a good seal? how are the bends in the aluminum and how are pieces joined together?
pics would probably explain all these questions anyway.
the aluminium is bent in a metal bender... it provides a near complete seal... box and lid are joined by allen head bolts... im currently setting up a website, so no pics yet.
give me your email and ill send you some pics.
cheers
Linton
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
