Have the RB20DET out of my GTS4 for sale. It was a running engine when I removed it (upgraded to RB25DET). It has had the timing belt and water pump replaced in the last 10k km. It is minus turbo and coil packs. Complete with 4WD sump, but I'm led to believe you can fit a 2WD sump to it.
$750 (delivered in metropolitan Melbourne). Freight anywhere else at buyer's expense.
https://www.sau.com.au/forums/topic/74366-rb20det/
to save blind_elk some hassle, guys keep in mind this is a RB20 for an AWD car (not RWD) and to make it RWD you need to change the bottom of the block to that of a RWD model.
https://www.sau.com.au/forums/topic/74366-rb20det/#findComment-1368519
