Hi Guys,
I recently bought an R32 GTR and today I found a Blitz Access ECU. I was wondering if anyone knew of its features and capabilities. Could it be hooked up to a computer?
I also found some BOVs and found my intercooler wasn't stock...lucky me :rofl: Oh and If anyone could tell me how I can get down and have a good look at the turbos that would be great.
Thanks
https://www.sau.com.au/forums/topic/74386-blitz-access-computer/
i think the blitz access was a plug in type computer u cud buy off the shelf in jap already programmed, it offered better ignition timing and mapping compared to standard, i dont think it can be hooked up to a laptop. im not 100% sure though.
Short of pulling all the intake pipes off, you can't really look at the turbos properly
Best bet is to throw it on the dyno and see what she makes - you'd be MAD if you didn't to make sure its not running lean. Alot of jap remaps are not well suited to our fuel.
The BLITZ ECU is just replacement chip for the ECU basically.
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
