My Mate has a R33 GTs-T.
He fitted a frontmount intercooler and piping.
And when he started the car he forgot to put to put water in the radiator.
And started the car and left it running for 30 sec, but reved it a few times.
He stoped it put water in it and started it again but it idled rough then it chugged till it stoped. And now when you try to start it, it sounds like its running on 1 cylinder.
Any 1 got any ideas???
Cheers
https://www.sau.com.au/forums/topic/74424-r33-gts-t-fitted-frontmount/
Sure it was your mate.. it's ok we've all done stupid things in the past :) j/k
Firstly, how long was the radiator running without water?
There is no need to remove the radiator water when mounting a cooler but anyway,
check all the connections and silicon hoses from the piping of the cooler.
I'll admit to my stupid moment.. I installed a front mount and piping, left the car warming up for a bit then took it for the first drive with the cooler, barely drove around the corner till I heard a huge BANG!/POP! then the car putted and stalled. I shitted myself and rolled it back into my drive way... found that I hadn't tightened one of the silicon hoses properly and it blew off. *Bows his head in shame*
All the hoses are tight and on properly now. but still when he turns the key it only seems to try to turn over while the key is turned on!!! less than a minute without water. Strait after the install he did have a cooler pipe not on properly!!! but turned it off as soon as he saw the rich smoke comming from the exhaust. He then plumbed it up properly and it went fine till he realized the water wasn't in the radiator, so he stopped it again, filled it and tried to start it again and thats when the not wanting to start thing happened!! could it be a sensor somwhere???
i changed a clamp on a cooler pipe once. turns out as per story above i didn't tighten it up enough when i replaced the clamp
so down the highway and 'bang' off goes the pipe
it was a fair way home so i drove it running rich as hell
then car wouldn't hold revs :P
turned out that i had fouled the spark plugs... all i did was replace the spark plugs and worked fine :D
hope that's your soluion... (or your 'mates' solution)
Warren.
my suggestion would be to change the spark plugs or clean it ( you said it ran rich ) . I dont think the egine will over heat in less than a minute.
Make sure he hooks up the airflow meter ( i forgot when i did mine and i shat myself )
also one time i drove/limped 1k back home ( didnt realise front pipes had popped off and i had nfi )
if he up the boost and gets flatspots or boost cut, regap the spark plugs to .8mm
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
