Hey guys, just saw a story on 60 minutes about BASE jumping, and it really makes me want to go skydiving again, just thought id see if anyone else wants to go (its cheaper the more people that go). I was thinking of going in a couple of weeks on a saturday or sunday when im not working.
As far as cost goes, last time i went in a group of 5, it cost $250ish for the jump plus $90 for the video (damn expensive video, but ya gotta get the video of your first jump)
So yeah, just looking for EOI at the moment, and ill make a few calls during the week sometime
https://www.sau.com.au/forums/topic/74435-wanna-go-skydiving/
I did my first jump about 2 months ago and I'm doing my second in two weeks time.
I would recommend that everyone should do it at least once, it is probably the coolest thing I have done!
after this jump I'll be sweet for the course and my first solo jump - that should be duckin scary! gets a fair bit cheaper one you have your solo licence - jump for about $30 if you have your own chute.
Go do it!
wow thats really cheap! how much would it cost to buy a chute?
i'd rather use one thats provided by the proffesionals, i hardly trust myself to put a shirt on the right way, let alone pack the only thing stopping me from hitting the ground at a 200kms/ph
Not trying to put anyone off, but driving back from Sydney a month ago, driving past that skydiving place just outside of Sydney on the highway there were a heap of peeps doing the drop. The scary thing was we saw one person whose 'chute wouldn't open properly really close to the highway. They swung over to the side and landed just out of view, but they hit the ground pretty hard. Chute never opened properly.
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
