I'm installing a 25/30 using a powerfc into the 240 and have a few questions hopefuly someone might be able to answer...
1 Does a powerfc control air con, I'm not using air so will any problems arise?.
2 What else does the powerfc control beside the engine management?
3 Can these other items controlled by the powerfc be turned off?
4 What kind of signal does the rb25det manual speed sensor produce?
5 Does the signal run from the sensor, through the dash speedo then to the ecu?
6 Is the signal multiplied or divided along the circuit?
PS: Using the hand controller :D
https://www.sau.com.au/forums/topic/74436-powerfc-in-240z/
cheers some good reliable info there, actually its more than I needed but thats a good thing. I like this...
Are there any cool tricks with the PowerFC? Free mods etc?
A handy trick PowerFC owners use when they take car in for a service/work to be done they set the rev limit to 3000rpm and remove the hand
controller. This prevents the workshop from taking your car out for a fang on the roads and driving it like they've stolen it as the PowerFC
will cut the power at the 3000rpm rev limit interrupting the joy experienced by the joy rider of your precious car
https://www.sau.com.au/forums/topic/74436-powerfc-in-240z/#findComment-1366854
    • I think you're missing the point here Duncan, I was trying to say that if you want to go fast around and have a spare $80K to $100K, easiest option is to just buy another car instead of modding your Skyline. Sure blowing $80k to $100K would make it fast, but then you'll have a car that you can't drive on the street comfortably. But use that $80k, buy a fast factory car, spend like $7K on AliExpress pipes, email tune, tyres, pads and you can be fast, not to mention now you have two cars.
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
