Ok i have been reading the treads on tolulene and i want some.
Apparently there are two or more grades of tolulene avaliable, one costs about $50 for 20L. I was wondering what the other grades cost and do they do any damage to the engine?
ANd where can u buy them?
Im about to do a long country trip where only unleaded is avaliable, maybe even premium unleaded, what percentages do i mix either of the grades of tolulene at?
Cheers
Karl
https://www.sau.com.au/forums/topic/7444-where-do-i-buy-tolulene-from/
Makit hardware in erindale rd balcatta. next to marlows. 1L and 4L containers. Pay upto $23 for 4L.
Otherwise contact BP, not the service station.
There is only one toluene availible, its either pure toluene(which you want) or its glue remover (which you don't want).
I bought mine from shell here in adelaide for $47 for 20L. If you buy it as a solvent you pay this price BUT if you ask for it as a fuel additive you pay about $80. Ring your nearest distributer and c how you go. You Will be happy with the results:D
yep, depends how much you car puts out to start with. Mine has 166 then with the toluene it has 166. JUST dont get it on the paint work. I put some on an old strees sign and there was no paint in about 20 minutes.
Any of the bottle octane boosters will cause a coating on your spark-plugs, but I'm pretty certain that Toluene will not effect the cat or O2-sensor. I can run a full race fuel like VP (107RON) and it won't affect them so I don't see why Toluene would.
I wouldn't suggest using the stuff all of the time, cause its expensive, and most of the time unecessary. Use it for drags/racing or very hot days.
See'ya:burnout:
  • 5 years later...
No Matter What anybody Says.
You can not buy pure tolulene Anywhere.
Tolulene is the Most unstable solvent on the face of this planet.
The only way you can get it is to work in a oil Refinery.
But it is good for your car. It cleans your engine
mate, this thread is 6 years old. I know it's your first post on the board. but things have changed in 6 years. kindly try and limit your posts to threads that are current.
Guest
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
