i need help!!!
my car has the same idiling problem as most of the sau boys....
ive tried to fix this by cleaning the afm and other stuff along with it
tonight i decided to give the aac valve a go... so i did... pulled it out and everything.. cleaned it up with carby cleaner... put it all back together.. all workign fine... even got the idle to sit still at 720rpm
but.... now i lose heaps of power... i gave it a hit with .5bar... and felt a little bit of power loss... then i decided to give it a go at 1.0 bar .. and i can really rell the difference... i mean it takes so long to rev up to 6500 its unbelievable... i think it may have sometihing to do with what i did tonight... im pretty sure i connected everytying back up the way it supposed to be and im still checking to see if there are any leaks...
ive reset the ecu aswell... and still no powergains again... still stuck.... its almost asif the cluthc is slipping.. .liek i can hear the air going in.. but it feels liek the engines not doing anytyhing with it... i have no idea... but i think my missfiring is comming back at about 5500rpm... but ive got my plugs gaoped to .8 and tehy are brand new irridium ones too... new high flow fuel pump... new fuel filter and yeah....
its really strange... i justwant my power back for now... im over the stalling thing....
any help????
https://www.sau.com.au/forums/topic/74463-lost-power/
yeah ... but i only started top lose power last night... after i cleaned the aac valve.... i was told that it could be still wet in the electrics still where i cleaned it.. and so one of the valves might not be opening... but i dunno... ive also been told to disconnect the plug to the acc.... i had a look at my coils... looks fine... sill clean under the boot... ive just recnetly changed the plugs... about 2 weeks ago... gapped to .8, im going to groudn the fuel pump today... but i swaer at has to have something to do with me cleaning the aac... even tho its really strange... it shouldnt really affect power should it? i thought it was just an idle control for the cars accessories and that...?
its really annoying... because i need to fix this problem as ive got a new turbo and a few parts comming in by the end of the week...
thanx for your help
https://www.sau.com.au/forums/topic/74463-lost-power/#findComment-1367347
shit like that is so frustrating but i tell you finding the problem and fixing it is like a orgasm....lol
can the aac valve be taken out??
if so soke it in metho that will dry it out or if you cant take it out by a can of electrical cleaner that should also clean it but also dry it out
but if you have driven the car after the clean the under bonnet temps should have dried out
also coil packs can fry cuz they are electrical they can be damaged with out looking ****ed mine looked good to but after i got some new ones (second hand) made a real big diff and thay can go for no apparent reason like just out of the blue 1 of mine fizzled
now it will hit full boost again and hit redline without a prob
before would only hit 7 not 10 and would splutter after 5000 rpm apparantley very common
https://www.sau.com.au/forums/topic/74463-lost-power/#findComment-1367366
ill try the metho and that treatment... ohh and before i had my dyno run with this.. it started to pop and sounded like miss fire after 5000 rpm... now its back again.. but not as bad..
last time i jst regapped the spark plugs.. but now its all back again...
so strange...
its a pin.. coz i need it all fixed by the ened of the week.... and really low on funds!!!
https://www.sau.com.au/forums/topic/74463-lost-power/#findComment-1367402
ok.. ive just taken the car for a drive... seems to be sorta fixed... i get some power... but only randomly... sometimes it decides to kick in normally and some times it decides to kick in real real late... when it did kick in late.. i heard a loud pop from the exhaust... could this be fuel pump related?? im going to groudn the fuel pump now to check it out...
it could be a leak in a line...sure feels like it.. it sounds like there is one near the fuel rail... but im sure that its just the fuel going through... or the injectors making that sound... but apart from that ive checked everywhere around the car and i cant find any leaks in the lines..
but then again... could just the a valve in the acc or something not opening... as ive been told by a few people
https://www.sau.com.au/forums/topic/74463-lost-power/#findComment-1367498
mate it all sounds so familiar but my car has been built from ground up again so ive never driven it before untill two weeks ago so for me it all seems part or the build
but i was so stoked when i found that it was the coilpacks cuz lucky i had ordered 6 new ones from SSS automotive they where only $20 each
but i know how you feel i thought it was my computer like the turbo was to big for standard but it wasnt
just coil packs and plugs
https://www.sau.com.au/forums/topic/74463-lost-power/#findComment-1367871
yeah i had a really weired thing happened to me.... i set it on low boost... and everything was okish... it pulled and everything was fine... a lil jump with the power but yeah...
as soon as i put it back onto high boost... it felt like nothing was happening again... ive ive just groudned the fuel pump to a ground point on the car too... everything feels and sounds like its gettign enough air, and fuel into it... just that it takes so long to rev.. and the power kicks in very randomly... so your suggesting a new set of coil packs? hope it works...
https://www.sau.com.au/forums/topic/74463-lost-power/#findComment-1367928
ok .. checked the coil packs... they are all fine... i did take off the turbo as im getting a 2540... but i noticed that a bit of oil leaked from teh silicon hose..where the pipe joins... so im guessing problems could be froma leak?
another thing... i was told that if you do anything to to afm... youll need to get it recalibrated... even if you clean it with a spray can of brake cleaner??? BAH????
oh... an another question... is a gt2540... pretty much using the standard covers for a rb25 turbo with bigger internals with dual roller ball bearings??
https://www.sau.com.au/forums/topic/74463-lost-power/#findComment-1369630
i have reset the ecu.. , many times... yeah... some guy here in canberra says you need to recalibrate it.. but is was a bit sceptical...
i think it coudl be a combinatoini of things.. bu tthe only thing i havent tested is the crank angle sensor... but i dunno... any other suggestions?
https://www.sau.com.au/forums/topic/74463-lost-power/#findComment-1370203
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
