mine came like that... personally i dont like the aerial so i fixed it and pulled out teh plug.
this is how i did it:
unscrew the top chrome bit around teh aerial.
open the lining in the trunk, rear left.
take out the jack, and feel around for the motor.
unbolt and unplug teh motor and take it out...
i found that the cogs and the long white plastic thing with teeth were mis-aligned so i took it all apart and cleaned it all up.
regreased and realigned everything.. it is all pretty straight forward if you know
what your doing - if ur not sure then ur better off getting a professional to fix it.
That said - my radio works fine with the aerial down so you might want to leave it???
  • 2 years later...
hey guys ive tried to remove mine, ive unbolted the motor disconnected it but i cant seem to get it out..
the outside chrome part spins but doesn't feel like its unscrewing as far as it should.. any ideas? does it help if the aerial is up or down.
keep going. and the antenna needs to be down or you won't get the motor assembly out of the rear quarter.
  • 1 month later...
Can someone upload a photo of the aerial unit out of a R33, so I can see what I am tugging on. I want the aerial to remain down, so I want to disconnect the electric motor NOT unplug the aerial.
the antenna's bolted to a metal sheet that runs down the side of the boot. on the quarter panel side (ie the side you can get your hand to) there's a plug about halfway up that's a standard loom plug, it goes into the main body of the antenna at right angles. squeeze the clip and pull it out. It's white and has about 4 wires going into it.
the actual antenna wire is right up the top, and it goes in at a 45 degree angle.
  • 3 weeks later...
If it's stuck in the up position, how do you force it to go down without snapping it? I'd be happy if mine was down and stayed down, but it's stuck up and just looks stupid.
I will unplug mine this weekend and see if I can get reception still.
My aerial was permanently in the upright position. At the mo I just turn the car off, whilst the aerial motor is whuring away trying to decline, I smack the top of the aerial down with the palm of my hand. It takes one hit that is firm but not overboard, then it picks up on the teeth in the motor and goes down. The other way that I first used was to push it down, but the smacking method works for me best as it wont snap or bend the aerial.
Tried pushing it, it just bends a bit and won't go down. Will try it as the motors going down though and see if that does it. If it's down and the motor's unplugged, but aerial is still plugged in, you should still get reception.
  • 5 weeks later...
mine does the same except mine is just a lil bit up and wen i turn the ignition on or turn the car off you can hear the motor grinding....how could i solve that....do i need a new ariel or new motor as i still want to be able to use the lil button behind the steering wheel to have it up or down....anyone got any pics to help me please
  • 2 months later...
some one helped me out and snapped my arial off
so i just had a short and sharp piece of metal left sticking up
al i did was unscrew the silver cap on the outside and pull the rubber mounting bit out then removed the remainder of the arial and put it back together
so i have no arial and still get a 100% perfect signal..
some dick snapped mine off and left it next to the car... what i did.
Cut the top end off so i had 1 inch, and i glued this into the hole where the antenna used to be, So it looks fine, and sits in the metal casing. Had to also remove the white teeth plastic by cutting off and pushing what was left down with a screw driver.
I then unplugged the power from the motor, bu reaching into the boot trim underneath and feeling around, there seems to only be one plug, althernativly you can cut the power coming from the deck to antenna, should be hooked to the REM blue / white wire.
either way, still get perfect reception with the antenna down
im trying to get my working attena to stay down as it goes up when i turn the car on and down when i turn the car off.. like it nomrally should. however, i want to keep the atenna down. is there a power plug i can disconnect? had a look and i disconnected this grey looking plug, turened on my car, the attena still went up.... so i put the plug back in and felt round the motor, and felt this rubber tube at the bottom of the motor.. is this what i pull out to disconnect power? or...
that or is there a fuse somewhere that can be pulled out?
The rubber tube at the bottom of the motor is a water drainage tube...
  • 3 weeks later...
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
