  • Replies 158
Pete,
I can't see there being a problem, but is there any probs with not having rear seat installed for you drift day? What about passenger seat?
I may need to take these out to fit my wheels in. Although I'd like to keep the passenger seat since you'll have a guy that can give advice there
Cheers
Chris
Drivers list other drivers to pay on the day
Remember its on rain hail or shine
In the rain drifting is more about skill then all out balls
1. indi 90
2. cael 90
3. cash payed 90
4. matt porter 90
5. wayno 90
6. angela screpis 90
7. angela scrpis2 90
8. chris laverick 90
9. ben jagger 90
10. paul Jensen 90
11. CBS 90
12. exe 90 8/6
13. Andrew quintal 90
14. jas 25 t 90 16/6
15. Daniel d 90
16. Daniel d2 90
17. apathy 90
18. alan1 90
19. drift cat 90
20. jonathen tierey 90
21. Stefan 90 20/6?
22. aaron celorc 90
23. mick mate 90
24. mick mate 90
25. cash(jonathen t) 90 21/6
26. cj rossetto 90 21/6
27. “ “ 90 21/6
28. “ “ 90 21/6
29. “ “ 90 21/6
30. jacob 90
31. ben 90
32. rob hatfield 90
33. c weissel 90
34. “ 90
35. “ 90
36. Andrew vitu 90
37. chris nielson 90
38. Brendan 100
39. mark 100
40.
very true
you should come out dick and learn to drive mate
i would love to boys but this weekend is a big race meet at eastern creek.
plus of course there is the issue of me being soft to consider.
can't say i'm too keen to crash, but i did do my best last week after passing that bloke going into turn 1 at OP. very nearly didn't make turn 2. and spun it off two laps later. but they say if you don't come off you aren't trying.
    • I've sent JaseR33 a private message in the hope he gets an email and contacts you
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
