  • Replies 158
So did anyone care to comment on how well/bad I did/give advice? (silver 4dr 32)
I got a cheer when I went off into the dirt on the last turn in front of everyone. haha
It was so much fun, I am considering losing the 32, and getting a trailer/dedicated car to use for drift. but that's just a thought.
kewl. thanks guys. I know I was alot worse than the rest of the guys I went down with (white FC/blue 180/champaigne 180/stock sprinter) but hey, I gave it my best.
The problem with using the road car is;
1) I have to be able to drive it home...and home is 3.5-4 hours away from the track. This will limit how much I really try. I only tried to throw the car from last turn into turn 1, once, and that was when I ended up in the dirt, I don't think I am willing to try that too much with this car, incase I go off the other side of the track and find a wall.
2) I am not willing to go into a comp, as I don't want it bent up from me/other guy stuffing up (i.e. I won't go near other cars on the track)
3) Expense. I don't have the money to set this car up. If I sold it, got a $5k sil or something, then throw $3-4k in setup, I would have a decent setup I think, without spending anymore than what I have already.
So I will consider it over the next 6 months, and get to every Fatz Day that is run! (When's the next one! ?)
chris,
check out this: http://forum.r31skylineclub.com/index.php?...p?topic=25031.0
i started out with a 4door 31 just like this. i'm still shithouse but that's cause i lack talent hehe.
the 31 are easy to get the arse end out. rb30 has decent power. and this car is selling at a very reasonable price. i say buy it!!
I had my camera, but my friend didn't take any photos :P
We had a video camera on the hill, but the camera man was apparently VERY VERY bad (I havn't seen it yet)
I had my vid cam mounted in the car, but the glare means you can't see the track...you can see in the car fine tho. haha I was considering buying a helmet cam for riding, I guess if I do I can use it for drifiting too.
Anyone have experience with car cams? I am gonna grab some tint of cuts and put that infront of the lens and see if that takes the glare away.
    • I've sent JaseR33 a private message in the hope he gets an email and contacts you
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
