Hey all,
I am sure this would have been discussed before, but I can't find it, feel free to link me if you can find a thread about this!
I am looking at getting a Trust VSPL FMIC. It requires the piping to go through battery tray. I will need to relocate the battery.
A few questions I have
1) Is there a tutorial anywhere?
2) What Cable Size do I need? 2 Guage?
3) What are the legal requirements? (ie. certain type of battery? Additional case?)
4) Anyone got photos of their install?
5) What size/type fuse do I attach onto it?
6) I plan to use the car on the track. Are there any additional requirements for CAMS?
7) Anything you can think of that I haven't?
Thanks
Chris
https://www.sau.com.au/forums/topic/74488-r32-battery-relocation-to-boot/
you can get battery relocation kits from most auto stores.
not sure of the part number, but you get everything you need
steve
Legally, you need either a sealed battery or a battery with an external breather. See the group buys section for a group buy on sealed batteries.
I would use at least 2 gauge cable.
legal or not, id definetly recommend getting the battery covered. a little tale to help enforce why i think this...
my mate is a butcher, and he has a mesh glove that goes from finger tips upto his shoulder (so quite long). he also owns a bmw that has the battery in the boot. so one night after work he was getting ready to leave putting all his gear in the boot, and low and behold, a fire started. his bag caught on fire which held most of his gear, which he pulled out and threw to the ground. not only his bag, but some of the boot lining also which he put out with an old tshirt that was in the boot at the time.
his battery cover had come off and while throwing his gear in, the mesh glove at touched both the terminals, sparked everywhere, and set alight some of his boot.
i would definently get a battery cover.. you may not own a mesh glove, but what if youre throwing in a long screw driver, or your toolbox lid flips open, or some other electricity conducting material happens to be in your boot..
thats all from me..
s.
Thanks guys.
Anyone got photos of their installs? I was hoping to keep my boot 'tidy' as I was gonna do a custom sub install. So a battery in the boot causes problems for the idea. So a stealth install would be good (And also prevent metal gloves from shorting the batter out :rofl: ) Then again, this may cause problems with CAMS... I might give them a call.
For the record - I would use a sealed brattery, and a box around it.
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
