So....with a FMIC ill only be looking at a difference of 12P.S.I as opposed to 10P.S.I....cause if im correct a standard turbo cant be boosted more than 12p.s.i safely regardless? Is there a noticable difference in power i.e on dyno run? or is it really not worth the cost if im leaving my turbo standard??
Was that 20KW gain running a stock turbo at 13P.S.I?? And does anyone know if the amount of boost you can run safely depends on the model of the car? eg series 1 vs series 2 r33?
It depends on what car it is, what mods it has (if it isn't stock) and the over all condition that the car/engine/turbo is in. Every car is different, there are no 2 the same. A mate has the exact same car as his brother, one is a 89 gts-t and the other a 90 gts-t, now we are talking 3 months between build dates of them.
They are exactly the same, stock as a rock bar a aftermarket pod, and a end can. Both are stock internals and running gear yet one has 42 rwkw more when put on the dyno.
Why, who know's it could me a number of reasons, the tubro life and engine condtion, stock intercooler, the point is that no two cars are the same, therefor you can't base them as the same.
Sure you can use it as a guide line and go from there but what works for one doesn't mean its going to work for the other :cheers:
Could be to do with the R33 ECU being very prone to dropping timing when intake temps get up. Seems like the R32 doesn't mind so much?
I just bled up my boost to 13psi after fitting my front mount, but I can barely feel any noticeable difference as everything else is stock bar a k&n panel filter. It just drops most of the boost anyhow back to 10psi. Needs exhaust, needs better airflow to the filter...blah.
In other words, raising the boost by itself is pretty pointless.
Yer good point, the Rb25 being 9:1 comp would be closer to detonation, high intake temps probably tip it over the edge quicker.
barely any difference with 13psi... lol That stock exhaust must kill the turbo's efficiency, going from 10.9psi (stock boost with 3" exhaust) to 12.5psi I noticed a definite difference.
On stock 10.9psi feels N/A.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
