Hey Josh,
Whats up? If ur there I might have a R33 Bootlid badge that you might be interested in. If you are, then please reply to this message ASAP.
Regards
Nare
cool do u know if its for a series one or two??
https://www.sau.com.au/forums/topic/74540-attn-darkrams69/#findComment-1368328
Hey Josh,
Its a series one Bootlid Badge. My cousin got his skyline a few weeks ago (GTS-T) and he completely shaved the damn boot lid. LOL anyway How much do you want to pay for it? I've got my cousin on the phone right now
Regards
Nare
https://www.sau.com.au/forums/topic/74540-attn-darkrams69/#findComment-1368336
ummm my cousin'z got a series II gts-25t ..... what does the badge look like and will it fit the series 2 key-hole??
Oh mate,
The series 2 GTS-t should have the same keyhole, but i'm not sure. Maybe we can get some guys on this forum to check it out? I'm not sure whether the badge will fit properly either so....
Regards
Nare
https://www.sau.com.au/forums/topic/74540-attn-darkrams69/#findComment-1368342
ronin 09 thankz i've been looking for it-do u know what the link is for it
cheeers
just click on the user name above his avatar, then select "send PM" or similar.
When he / you have one, in the top right of the screen below "Welcome, darkrams69" wull be a link "Private Messages" - click there it tells you how many you have
https://www.sau.com.au/forums/topic/74540-attn-darkrams69/#findComment-1368361
Thx for explaining to him. I cbf lol. :wassup:
Regards
Nare
https://www.sau.com.au/forums/topic/74540-attn-darkrams69/#findComment-1368370
thanks a lot.
cheers, darkrams69 :Bang:
https://www.sau.com.au/forums/topic/74540-attn-darkrams69/#findComment-1368374
Guest
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
