i have a r32 gtr, and it keeps ripping the std exhaust side engine mount, i am converting to a rb30 so it will be higher 38mm???, my turbo is already hitting the bonnet (custom manifold) t8834d how can i lower engine (it has a 10mm spacer already) with mounts, and create a stronger mounting setup in the process
any one made ther own mounts? or lowered there engine? from the 4 bolts on block? or via the mount itself
urethane?
other plastics?
alloy? (what are the side effects of a true solid mount)
and how much and a rb30 (4wd with 10mm adaptor) be lowered on a gtr 32 sub fram without contact, i may be able to angle engine on exh side to stop turbo hitting but relise there will be some bonnet mods required,
see pic, this gives you a idea how high already (with rb26 engine)
You're screwed. If you try to lower the engine 30 mm and then add a 10 mm adaptor for the 4wd, this means the sump is 40 mm lower, the gearbox is 40 mm lower, the front drive shafts are 40 mm lower etc etc.
About 5 years ago I built an RB30DET (RB30E/25DE) in an R32GTR and it cleared the standard bonnet easily. By enough to have a rather thick strut brace as well. So there is no basic problem wiht fitting an RB30 into an R32. I believe your ONLY answer is to lower the turbo. It is far less complex and less prone to introducing other problems.
As for engine mounts, I suggest an engine brace would be a good idea if you keep ripping LHS mounts. This is not unusual as RB's turn clockwise, consequnetly there are a number of brands of engine braces with shock aborders available . Nismo make rubber hardeness up engne mounts and Noltec have polyurethane mounts.
I have a couple of cars with solid mount engines (Super Tourers) and they vibrate horrendously, stuff is always falling off and cracking. Not something I would recommend.
Hope that helps:cheers:
Noltec have polyurethane mounts.   do they have a web site? yea i think ill just modify my bonnet, manifold looks to well done to hack up, racepro in nz make a bonnet with a vent right above where it hits,
www.noltec.com.au
I have had a closer look at your photo, the turbo doesn't look particularly high. Does it only hit on the bonnet when the engine is flexing? Or is it on it when at rest?:rofl:
the gearbox and axel angle shouldnt mater that much, i am more worried about hitting the sub frame, what if i angle the engine more so exh side is lower and intake stays the same? that way only the front driv shafts should be affected, the gearbox will just twist on its mounts, this may give me a little height decrease
www.noltec.com.au
idd say only when flexing, but monuts were ok when i removed the 26 engine on saturday, it has a small mark on top of turbo and a small mark on bonnet where they had been rubbing, nothin major, would a bonnet look gay with a hump where the turbo sits? it may look good with a hump and a reverse bonnet scoop tho?
i should of taken a picture side on before i reomved engine, here is a pic with brace insatlled
if you see the manifold picture is it to complex to re weld, if it was just the pictured filter that hit i wouldnt worrie, but since its the comp housing itself i sorta have to, i couls also rase the bonnet at the back for heat flow, this will help a litte , but not 38mm, 38mm is deck height increase with 26 to 30?
Ah, it's not the height of the turbo that is the only problem, it is mounted further forward than usual as well. This is where the bonnet droops down towards the front. Personally I would change the angle of the turbo mount flange on the exhaust manifold. Angle the turbo downwards at the front and rotate it 15 degrees clockwise. Not a particualry difficult job for a competant welder.
RB30 is 85 mm stroke and RB26 is 73.7mm stroke, so that's 11.3 mm longer stroke which = 5.65mm taller block to accommodate the extra stroke. In addition the RB30 conrods are ~30mm longer. Hence the usually accepted number is ~35mm taller.
:cheers:
although that will mean a new / refitted dump as well then
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
    • Wonder what the cause is, but here's hoping it's nothing too serious.
