i have a r32 gtr, and it keeps ripping the std exhaust side engine mount, i am converting to a rb30 so it will be higher 38mm???, my turbo is already hitting the bonnet (custom manifold) t8834d how can i lower engine (it has a 10mm spacer already) with mounts, and create a stronger mounting setup in the process
any one made ther own mounts? or lowered there engine? from the 4 bolts on block? or via the mount itself
urethane?
other plastics?
alloy? (what are the side effects of a true solid mount)
and how much and a rb30 (4wd with 10mm adaptor) be lowered on a gtr 32 sub fram without contact, i may be able to angle engine on exh side to stop turbo hitting but relise there will be some bonnet mods required,
see pic, this gives you a idea how high already (with rb26 engine)
You're screwed. If you try to lower the engine 30 mm and then add a 10 mm adaptor for the 4wd, this means the sump is 40 mm lower, the gearbox is 40 mm lower, the front drive shafts are 40 mm lower etc etc.
About 5 years ago I built an RB30DET (RB30E/25DE) in an R32GTR and it cleared the standard bonnet easily. By enough to have a rather thick strut brace as well. So there is no basic problem wiht fitting an RB30 into an R32. I believe your ONLY answer is to lower the turbo. It is far less complex and less prone to introducing other problems.
As for engine mounts, I suggest an engine brace would be a good idea if you keep ripping LHS mounts. This is not unusual as RB's turn clockwise, consequnetly there are a number of brands of engine braces with shock aborders available . Nismo make rubber hardeness up engne mounts and Noltec have polyurethane mounts.
I have a couple of cars with solid mount engines (Super Tourers) and they vibrate horrendously, stuff is always falling off and cracking. Not something I would recommend.
Hope that helps:cheers:
Noltec have polyurethane mounts.   do they have a web site? yea i think ill just modify my bonnet, manifold looks to well done to hack up, racepro in nz make a bonnet with a vent right above where it hits,
www.noltec.com.au
I have had a closer look at your photo, the turbo doesn't look particularly high. Does it only hit on the bonnet when the engine is flexing? Or is it on it when at rest?:rofl:
the gearbox and axel angle shouldnt mater that much, i am more worried about hitting the sub frame, what if i angle the engine more so exh side is lower and intake stays the same? that way only the front driv shafts should be affected, the gearbox will just twist on its mounts, this may give me a little height decrease
www.noltec.com.au
idd say only when flexing, but monuts were ok when i removed the 26 engine on saturday, it has a small mark on top of turbo and a small mark on bonnet where they had been rubbing, nothin major, would a bonnet look gay with a hump where the turbo sits? it may look good with a hump and a reverse bonnet scoop tho?
i should of taken a picture side on before i reomved engine, here is a pic with brace insatlled
if you see the manifold picture is it to complex to re weld, if it was just the pictured filter that hit i wouldnt worrie, but since its the comp housing itself i sorta have to, i couls also rase the bonnet at the back for heat flow, this will help a litte , but not 38mm, 38mm is deck height increase with 26 to 30?
Ah, it's not the height of the turbo that is the only problem, it is mounted further forward than usual as well. This is where the bonnet droops down towards the front. Personally I would change the angle of the turbo mount flange on the exhaust manifold. Angle the turbo downwards at the front and rotate it 15 degrees clockwise. Not a particualry difficult job for a competant welder.
RB30 is 85 mm stroke and RB26 is 73.7mm stroke, so that's 11.3 mm longer stroke which = 5.65mm taller block to accommodate the extra stroke. In addition the RB30 conrods are ~30mm longer. Hence the usually accepted number is ~35mm taller.
:cheers:
although that will mean a new / refitted dump as well then
    • Ha ha ha, mine loves to spend, all on the dogs (they're our kids, and her spending would likely rival that of some people raising children!) the only benefit is, her spending is tax deductible as she runs a business in the dog industry 😛 The above all means she can spend race car budget quicker than I can. 😛 That and a lot of the things I want are very expensive, and I can be a bit "you want how much for that?!" And at other times overly impulsive. Or I start the w days of research, get to day 1.5 and get really annoyed that no one will advertise actual specifics and it's just marketting BS and I go "well, now I don't want anything to do with that now!" Also I hate paying lots of money for something I can make from $50 in materials. Then I get the shits halfway through making things and wonder why others who just buy parts have more fun... 😛
    • Their 240Z with the RB26 would be a real nice thing to have in a garage to come out for an occasional weekend cruise It's such a cool thing in so many ways Sadly, we have a blue 240Z shell that I walk past every day, just sitting outside a shed at work, it has been slowly disintegrating and falling apart into the ground for the last few years, the owner cannot be found, and I am unable to "claim it" I've been told by work and the RMS, the rust in the body is excessive though, and it has had most of the salvageable stuff, like panels, trim and switch gear stripped off it over the last year or two, work keeps threatening to put it in one of our metal scrap bins, I wish they did though, as it makes Mark sad walking past it
    • Good tips, I like it! 😂😂 My wife is a LOT more frugal than me so it's only me we need to worry about! A splurge to her is buying 2 pairs of socks in one visit at Kmart!
    • Haha, the appropriate response to the question "Is this new?" is "I've had this for a while.". With the unspoken small print that a while may be the time since this morning or five years ago   And to be fair I learned that from the best, i.e. my wife. Because it goes both ways.
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
