Cold air partition installed and now running a bit crap
didn't need the passcode. just needed to put it on a USB. It did the reset but still goes to a black screen after booting up.... this is the file i used if anyone needed to reset there Mark 7 AUCAR T Style for Q50 Q60 back to factory settings https://u.pcloud.link/publink/show?code=XZKbcQ5ZVKVdSGRFSD7wcTLoYyFE0ydGXBX0
You work fast and efficient, all that would have taken me at least 2.5 years LOL -
252mm to the centerline of the bottom mount. BTW the front springs were originally 8kg.
Yes, well.... get the main wire off the back of the alternator and try again?
So.... here's one for @GTSBoy ..... I plugged up the battery in the boot, to my surprise no sparks, no shorts, alarm went off, dome light on, etc. tried to crank the car, motor rotated a few times. Battery is pretty flat so will need more juice before I try to start it. With the battery plugged up at the back, when you pop a volt meter across the chassis and the jump point, you get a nice 12V, no issue. However, when you disconnect the battery at the rear, you straight up get a short. My broscience is thinking there's some issue with the rectifier, dead diodes perhaps?
