T04E 3in i .50A/R compressor inlet, 2in .63 A/R outlet, wet floating ball bearing.
i currently have the turbo but am selling on behalf of a friend, and as per the rules im taking full responsability for the sale, he asked me to sell it for anything close to 1000 but its open to offers. thankyou
https://www.sau.com.au/forums/topic/74585-t04e-turbo-for-sale/
wow!! thanks for the info... i was tempted to buy one of these cheap turbos on ebay but lucky i didnt... i usually go to performance auto shop to have my engine done ie:intercooler,exhaust etc....but ebay almost tempted me...
thanks for the info :P
PS: i aint saying this dudes turbo is cheap but the ones on the link.
:mad:
listen guys ill have a look at the turbo today, and if it the same as the one on the websie then ill take it off the for sale section, but then again it is still a turbo and is still for sale. i dont think that every turbo made by this brand is proned to failure, might be a small batch, but then again you never know.
