T04E 3in i .50A/R compressor inlet, 2in .63 A/R outlet, wet floating ball bearing.
i currently have the turbo but am selling on behalf of a friend, and as per the rules im taking full responsability for the sale, he asked me to sell it for anything close to 1000 but its open to offers. thankyou
https://www.sau.com.au/forums/topic/74585-t04e-turbo-for-sale/
wow!! thanks for the info... i was tempted to buy one of these cheap turbos on ebay but lucky i didnt... i usually go to performance auto shop to have my engine done ie:intercooler,exhaust etc....but ebay almost tempted me...
thanks for the info :P
PS: i aint saying this dudes turbo is cheap but the ones on the link.
:mad:
listen guys ill have a look at the turbo today, and if it the same as the one on the websie then ill take it off the for sale section, but then again it is still a turbo and is still for sale. i dont think that every turbo made by this brand is proned to failure, might be a small batch, but then again you never know.
    • Yep, replacing all those hoses is kind of just bog standard if you're ever back there. Only hose on the back of the engine I have yet to replace is a vacuum hose for the wastegate. I'll probably do it eventually but it's in such an annoying spot.
    • I was actually just planning on replacing the fourth gear parts in the gear box that I broke … like the synchro hub or cone. And any other parts I need once I open up the transmission. That a bad idea? The rest of the gears feel tight. these parts shouldn’t be too much … just the labour here won’t be cheap. Just replacing these in HK would be around 2k aud including labour.    how much is a new r33 or r32 transmission?    thanks for the good info as usual
    • I chose a bad time to buy, at the time there was no gtst's for sale in NSW and my options were qld, vic, or sa and not the greatest examples or too far out of my budget. Ended up picking this one from adelaide sight unseen and got a bit stitched up as you could expect but i dont fully regret it, its just a shame people cant be more transparent in this day and age.
    • IMO just buy a whole R33 transmission and swap the whole thing. Use a palm nailer/air hammer with a roll pin punch to drive the shifter rod end roll pins out. The rod end is discontinued so don't break it. Use gasket dressing on the OEM paper gasket instead of RTV. I personally would not pry on the shifter cover tabs, I broke one trying that instead of just smacking the side with a dead blow rubber mallet to shock it loose from the RTV the last mechanic applied. If you can't get the flanges totally clean and free of any residual RTV and/or you might have a gap that is bigger than it should due to flange damage use RTV on that surface instead of the OEM specced anaerobic sealer. Anaerobic sealer is most likely the right sealant for the job, it's just too easy to mess it up with too large a gap or bad surface prep/roughness seemingly. If you do rebuild what you have it's for a whole gearset that can take high torque. Don't bother with OEM at that point.
    • Little hose. Big hose. They're all waiting to kill the engine.
