Just wondering if anyone knows how to get that wicked 'flutter' sound, when backing of the throttle on a turbo. Im not sure, but I think it may be the wastgate? Or is it a particular type of BOV? Heaps of tough VL RB30's do it, specially that yellow Bresciani racing monster!
https://www.sau.com.au/forums/topic/74592-how-to-get-that-flutter/
Block off you blow off valves so that all waste air from closing the throttle has to go back through the compressors on your turbos. This will cause massive surging to your turbos - some people say it damages them - and make that flutter sound. Problem is you slow the turbos down every time you hear it, causing it to take longer to get back on boost.
In short it isn't the sound of an effective street turbo setup unfortunately.
Yeah my car makes that noise, u just have to push it really hard to get it. Reason mine does it is that my stock BOV cant support the ammount of boost im running. Its not good for the turbo so dont do it. Need to find me some Twin GT-R BOV's.
Im puttin one of those new exhaust tips on so it goes, wooo wooooo wooo woooooooo
http://media.ebaumsworld.com/bubbrubb.wmv
pwwahaha "das early in the mornin , got be up cooking breakfast by den" magic !wonder if my bovs will make it on sandra sully's table this arvo ?
i just bought a new stock bov coz the stock one that was on the car when i bought it had been welded shut to stop it from opening
i'll take a pic tonight of the bottom of it to give you an idea..... sounds cool for a bit, but you get sick of it lol, and it does slow you down, coz the turbo almost needs to respool after every gear change.
-ruffels
mine flutters with a turbosmart BOV.. the tension in the spring is just a little tighter so that the air cant hold the piston open for long, so it does lots of little sharp bursts
only does it when you ease off the throttle tho, when you let off fully its just a normal bov sound
Yeah, when I took my car for a drive once it was cleared by customs it made that sound, turns out there was a screw in the stock bov, so they had blocked it off for that sound. Sound was sweet, but does the turbo no good. I haven't heard the sequential bov, would it make a similar sound though????
I CALL BULLSHIT
Bullshit yourself mate, you dont know anything about my car. A stock BOV cant handle 17 Pounds of boost...
Damn i didnt know people were so dumb in western australia, guess its true what they say
Considering most stock bov's leak in between 12-15psi, that's where the bullshit factor come into it, and if you're not bullshitting your losing power. I'm sure running 17psi with it is doing your turbo a world of good too.
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
