Hi guys, i am looking at exhausts, I like the Apexi N1 Dual, though people only seem to be selling the Single now..
I am a little cautious of getting a custom job as obviously the big companies put a lot of money and research into it, and i have reservations of someone just throwing something together..
i am interested in mid-high range torque increase
Just wondering if anyone has one and how loud it is? i don't want it to be rediculously loud (like the 1.8L mirages these days), but have a nice note and really open up when the throttle is down..
anyone else got any suggestions.. i liked the look of the N1 Duals and the theory that it increased midrange (i think N1's are for High range), There are also GT ones as well, but i am not too fussed about stainless (though i think the pipes are bigger?)
Has anyone seen / got a titanium N1?
Any help / comments appreciated
https://www.sau.com.au/forums/topic/7460-apexi-n1-exhaust-or-others/
I also have an Apexi N1, the note is aggressive but not too loud and annoying like some others. I would tend to go for a Japanese style muffler, but the rest of the system may aswell be local, just get a 3" system, with dump pipe and separate wastegate pipe with hiflow cat.
See'ya:burnout:
I have the FGK (FitsuboGiken) exhaust from cat back. It is the quietest jap exhaust I have heard on a skyline appart from stock.
It has a nice deep 'pur' on idle and lets you know you what the engine is doing when you give it heaps. It looks good and does the job without the 'cop-bait' noise and has excellent quietness when on cruise. Makes your car more of a 'sleeper'.
Originally posted by 51jay
rev210    The FGK sounds like what I'm looking for, where did you get yours?  My current one has a fairly loud(in the ****pit) and very annoying drone.
Hmmmm!   I've been censored!!
Mines the Super Ti (titanium rear muffler)
you can buy it from fitsubo themselves, I got mine with the car.
It quieter than stock exept for the full throttle revs.
http://www.fujitsubo.co.jp/mc-prod/
The only thing with Trust is it doesn't have any markings on it except the JASMA certification plate. You only got a piece of paper if you buy new to prove that it's a Trust item :D
Mine just arrived...
At least the muffler barrel not that big so it won't hit the speedbumps near my workplace....
Originally posted by rs73
The only thing with Trust is it doesn't have any markings on it except the JASMA certification plate. You only got a piece of paper if you buy new to prove that it's a Trust item :)
is this true?
cause i was cleaning my zorst the other day and seeing if my Kakimoto one will fit, and there is a JASMA plate on it... i didnt know what the **** it was, did a search nd found this...
comments?
cancel that...
JASMA
Often owners may find 'JASMA' stamped on an aftermarket exhaust that was on their car when they bought it. JASMA is not a exhaust manufacturer, its some sort of organisation that certifies exhausts meet noise standards etc. It stands for Japanese Automobile Sports Muffler Association.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
