Ok...a few generalisations first...:D
You have two turbos both flowing 60cfm into the same engine. The inlet temps are the same but in order to supply the 60cfm one of the turbos has to run 20 psi vs the bigger turbos 14psi.
So which turbo will make more power?
Firstly let me say that I think that scenario is impossible. There is no way (that I know of) for a smaller turbo at 20 psi to supply 60cfm at the same temperature as a larger turbo does at 14 psi. In addition to turbo rpm differences, there would be some engine rpm differences (ie; the larger turbo is going to need more engine rpm to produce the same airflow). Since "power" (horsepower I assume) is torque X rpm / 5250, the different engine rpm would make a comparison difficult.
But let's say it is possible, I believe that the larger turtbo will produce more power because it has less exhaust restriction (via the larger turbine). If this (larger turbine) is the primary reason for the 14 psi versus 20 psi, then the extra power will be substantial.
:cheers:
https://www.sau.com.au/forums/topic/74606-boost-and-power/#findComment-1369374
Just my thinking but wouldn't they have the same total power apart from the obvious lesser exhaust restriction as SK said, but the larger turbo spool up much later in the rev range and the smaller turbo spool up quicker therefore the smaller turbo would give the power quicker than the bigger one......does that make sense?
https://www.sau.com.au/forums/topic/74606-boost-and-power/#findComment-1369496
you need a mrs troy
Stuff that, recent times have proven they are more trouble then the R32:)
Im curious to try a new turbo that is a bolt on to my setup. Basically im running about 17psi to make 235rwkws.
My current turbo flows about 42-45cfm. The turbo i want to run flows around 60cfm. Now here is the thing the turbo uses the exact same turbine as i currently run, the same exhaust housing, just has a bigger compressor and associated compressor housing.
The diameter of the wheel is 3mm, maybe it was 4mm bigger then what i currently run.
Could be interesting to see how it performs
https://www.sau.com.au/forums/topic/74606-boost-and-power/#findComment-1369519
My guess.......More airflow to make more power = more boost, as the turbine is going to be a restriction at the higher airflow. This usually means closer to compressor surge, as the compressor can deliver more flow than the turbine can receive. Usually Trust add larger turbines for more power, this avoids the compressor surge issue.
Should be an interesting experiment none the less.:cheers:
https://www.sau.com.au/forums/topic/74606-boost-and-power/#findComment-1369552
If you run the same PSI (17) as you curently do won't it just make the same power more or less, just later it the rev range thus making the upgrade faily useless unless you run more boost?
https://www.sau.com.au/forums/topic/74606-boost-and-power/#findComment-1370216
This is where i was looking for ppls feedback as the theory goes out the window i suspect in application.:P
If i run 17ps with a 2530, then 17psi with a 3037 then i would hope the 3037 would make more power:) Thing is what happens when you run the 3037 compressor and cover on the the 2530 turbine:confused:
You would think you get surge city. But the TD06 turbines flow a lot more then a 2530 turbine, and provided my exhaust valves and head etc are a restriciton before my Trust turbine/housing then i wonder if its possible that this setup may just do the job.
It will be interesting little experiment.:mad:
https://www.sau.com.au/forums/topic/74606-boost-and-power/#findComment-1371288
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
