The other day it rained heavily over night and in the morning, anyway when I started my car the next day (its left outside - nothing I can do about it) the starter motor noise was about twice as loud as normal and is more of a screech. It starts fine so I dont see it being a problem, but if its a sign its about to die or something it'd be great to know in advance.
https://www.sau.com.au/forums/topic/74622-starter-motor-screech-on-r31-rb20/
Remove the starter motor.....2 x 14mm bolts on drivers side of car. Get the upper bolt from the top and jack up the car and get the lower bolt from underneath. Inspect the starter motor gear and slip clutch. Make sure it spins fairly freely. It will be firm but make sure you can actually turn it. Make sure there is all the teeth on the gear. With starter motor out you can also see the ring gear on the flywheel/flexplate and you should inspect tihs also. Make sure there are no missing teeth. Post pictures if you like or if you can.
if say there are teeth missing is this an issue, does it mean its likely to get worse and not start properly? I'm one of those people who will wait till its broke to replace it :P
last year my starter used to make the noise of when you try and start that car while its already on. was so anoying and rather embarasing when i started it around other people. i pulled it out and greased the shaft. has been working great for about 3/4 of a year now. i suggest you try it before byung a replacement.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
