Yeah, I reckon its was some synthetic fluid that started to make mine leak
I have used the Castrol stuff in the red bottle this time, just by pure chance :P
Its the blokes down at ACBS that warned me away from Synthetic fluid. :P
I couldn't believe my chances though, just pick the master cyl up and mine completely pops, I drove home rev matching, switching off at traffic lights, in to first and crank the key. lol
I topped my old master cylinder up before my last Mallala day with synthetic/silicone fluid I was using in my brakes. A week later the seal started to leak. It was always a constant leak though, so I just kept topping it up with the Castrol stuff.
either way its fixed now, and has a resivior full of Castrol fluid!
Good effort to get home with no clutch. Poor ol' RB20 'box!
I asked the guy about my pedal bleeding off slowly, and he reckons it has to be the master cylinder, not the slave.
The slave will only leak fluid, or suck in air. Good way to tell which is stuffed (master or slave) is to block off the line and press the pedal. If it bleeds off its the master :P
He rekons 1 in 50 or so come brand new that are stuffed, so be aware, you can get a dud newie....
You had a dud newy did you not?
I learnt how to drive with no clutch in my first car. The TE Cortina's used to have a surclip to adjust the clutch cable, the damn things would always flick off leaving no clutch. :rofl:
Your clutch was bleeding off like mine.
Its farked, I'm telling you now.
I held my foot slightly on your clutch pedal and it went half way to the floor. :rofl:
Exactly what mine WAS doing.. Now it goes straight to the floor and makes nice squishy sounds.
Having a clutch that isn't bled correctly will cause you to crunch gears and not dissengage the clutch completely.
Clutch master done. :P
I didn't have time to fiddle with the pedal box today as I buggered around removing the little silly box that locate between the master and the slave cylinder.
I simply straightened the end section of the old metal piping then rebent it so that it mated up with the rubber hose that then runs to the slave cylinder.
The clutch seriously feels so much better now. Seriously I tell you. :D
I swear it feels lighter, more springy and much more progressive. Previously it was very bitey now it is much nicer to drive.
Ignore the rust mark on the floor pan. Thats an old heater that went pop under the inlet manifold. The camera really shows it up as orange. I should clean it up really.
  • 1 month later...
The forum change over broke a lot of links, using the WHITE PAGES would have got it for you, but here's the detials anyway:
ALL CLUTCH & BRAKE SERVICE PTY LTD
3 Pinn St St Marys 5042 (08) 8277 8122
Email [email protected]
Internet www.allclutchandbrake.com.au
Edited by Oosh
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
