Originally posted by R34_GT-t
Hi Minh,
I've seen your topic on the UK forums. :D I'm sure many people will register. :D
Regards,
-Elliot
Hey Elliot. Its gettinglate in the UK now isnt it?
You sleep late?
Hey come to this thread we are having fun
http://forums.skylinesaustralia.com/showth...=&threadid=7459
https://www.sau.com.au/forums/topic/7464-hi-everyone/page/2/#findComment-110633
Oh dear I seem to be mentioned on this thread a fair bit :D
Im Lee, and have followed Dr GTRs links again from the UK forum.
Dont have a Skyline though, just a GTiR and an RX7 - the time will come. Wanted to go drifting instead so got the RX.
I believe these were being talked about...
Shame some of the better pics came out a bit blurry :D
Cheers
Lee
https://www.sau.com.au/forums/topic/7464-hi-everyone/page/2/#findComment-110685
Yep, that's exactly the sort of thread I was trying to warn you about - they all seem to go that way these days:lol:
https://www.sau.com.au/forums/topic/7464-hi-everyone/page/2/#findComment-110711
XrSiSt, sure you can modify cars in the UK. You should see the amount of Max Power type cars on our roads. :)
I'd say! You guys were blessed to have that Top Secret guy come over with his toy and put on a show. And how can I forget the cossies! Love the cossie motors. My favourite 4 cylinder motor.
https://www.sau.com.au/forums/topic/7464-hi-everyone/page/2/#findComment-111470
    • I was just going through this on Neil's car (33 gtst). Assuming you are using standard AAC and Cold start valves, you need Post Turbo Pre throttle to Boost Controller (if you have one) then to Turbo Wastegate Pre throttle to AAC input AAC input T piece to Cold start input Cold start output to plenum post throttle AAC Output to plenum post throttle AAC Output to brake booster (needs a 1 way valve) Plenum post throttle to Fuel Pressure Regulator Plenum post throttle to Blow off valve signal Plenum post throttle to Boost controller input (if you have one)
    • I’m trying to figure out the purpose of these fittings. Assuming they’re for coolant but not sure where the lead to. I know the bigger one on the right (which isn’t filled) is the brake booster. If anyone has a photo of a diagram of this intake or has a set of instructions it’d be greatly appreciated
    • How much is that r32? Is that $170k or $1.7m
    • Ahhh! My silly brain was thinking Nissan started selling them straight away, but they waited w or three years didn't they?   Maybe Duncan should build an R35 race car over the V37... There's a cheap yellow one on car sales Duncan, would only need your splash of purple added...
    • Welcome (back) Gaston! Keep us up to date with the hunt!
