i removed the rb26 from a r32 gtr on sat, and i damaged the annoying ps line, also the plugs for ps switched and solinoilds,
whats are they for? the one in alloy housing right on rack, and the one in front off diff,
i have disable hicase and removed all lines and systems etc, i want to simplify the p/s system further,(replace bent lines while im there, )
any racers done this?
or is it ok jsut to leave them unpluged?
If you are ciiruit racing then you will need the power steering. The amount of caster you need to run makes the steering very heavy especially with decent racing tyres (slicks or "R" type). We also run a power steering cooler as the fluid gets hot after a 20 minute race.
If you are drag racing, then ditch the power steering, saves weight and power loss. Stick some bolts in the holes in the rack where the pipes are removed, keeps the dirt out. Makes no difference to the rack, just heavy steering. But you are only driving in a straight line, so it doesn't matter.
this
sounds like me, but what about these electrics i thought it was all for hicas? you think a cooler is a must? remember only hicas needed the cooler, non hicas models dont have one,
Has anyone found a manual rack that fits?
Why? A steering rack is a steering rack, manual or power steering there is no difference in the rack itself. The only change would be the steering ratio, manual racks have slower ratios to lighten up the steering effort. But I wouldn't think you would want slower response to steering inputs in a race car.:(
    • Ha ha ha! I know those feels mate I've finally got the garage cleared enough that next weekend I'll do some actual work on my car (hopefully). Unfortunately garage isn't usable after 10am at the moment That said, I've done a lot of work this weekend on helping finalise a friend's Production Race car. Full started Christmas Eve. We're down to about 8 tasks on the list, including "get a wheel alignment". Sometimes it's just easier working on someone else's car or project than our own stuff 😛
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
    • hmmm that's not ideal. This is a pretty new engine right, will be interesting if your engine guy has any theories about causes
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
