HEY
Im about to buy my first skyline, r33 gtst!
I have a few questions..
Do 95model R33 GTST come with stock boost gauge in the dash? If so, then did all turbo models come with the stock boost gauge??
How can I identify if the car was NA and converted to turbo?
Also the car has blue and white GT badges.. whats the deal with that? Arent they ussually Red and White?
Thank you, I just have some concerns that the car was converted to turbo from NA!
Any help will be appreciated!
Thank you
https://www.sau.com.au/forums/topic/74683-help-few-questions/
r34_skyline, are you dumb?
There is a high likelyhood that the badges could have been replaced, either someone badged the car previously, or it was mocked up to look like a non-turbo for compliance reasons.
He hasn't answered his own question, if he had known the answer, he wouldn't have asked now would he?
dumbass.
gl abo
dumbass.
gl abo
ummm thats what i said, minus the compliance bit. when i said he answered his own question, i was referring to the part about the turbo conversion.
no need to get off ya high horses just becoz u didnt interpret my answer correctly.
also, why in the blue hell would you mock up a turbo to be a non-turbo for compliance reasons ?
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
