Hey had my avcr in for a while
got autobarn to install it (slacks creek)
and apc to tune it to 10psi
both settings on the avcr are goin up to 0.8 bar
im wantin to put it back to standard boost
cause anythin over 0.6 boost just not goin as hard
should i just go to a performance joint and get them to set it
or is there a eaasy way to put it back to standard (preferably puttin it on to Setting A.
Thanks
if they didnt run the power and earth wires exactly like they tell you to in the manual it wont change the boost..
when installing mine i earthed it just to the bracket that holds the ecu in place and it wouldnt adjust the boost... just ran stock boost.. went back and earthed it to the earth wire on the ecu that it tells you to and it worked..
maybe check that
