Home made turbo...
I would like to put an RB25 compressor wheel and cover onto a VG30 turbo. Does anyone know if I can do this at home or is it something that needs to be done by a professional?
To do that is very easy , since the ceramic turbines are the same just exchange the exhaust housing on the RB25 turbo for the VG30 one .
Going inside these Hitachi cores seldom works , the big drama is retaining the ceramic turbine when torquing up the compressor lock nut . Mostly the turbine pops off the flanged (hot side end) of the shaft where it was bonded together . Its usually cheaper to replace these cores when they die with another one than it is to attempt repairs .
I've never seen the R34 GTT turbo except in the above mentioned post . Nissan would have taken full advantage of the Neo engines more sophisticated engine management and variable cam timing , which would allow the turbo to have higher gas flow and not loose low end torque . From memory the RB25 Neo made 206 KW and the earlier version around 185 , I suspect the R34 turbo was altered to support this . I am curious to know what the power curves are like between the RB25 Neo and the std RB26DETT .
Cheers A .
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
