hi all,
I'm going to be pulling my steering system apart this w/e and while I;m there i figured i may as well pull the radiator out and flush it (and as a bonus i'll have more room to work).
I noticed that the air con piping runs *through* the radiator to (well i think its called) the condensor. is there any way to take the radiator out without de-gassing the a/c system?
If i do have to de gas the system, how do i do it? what should i be careful of?
Any help appreciated :D
Thanks,
Michael :(
mine looks stock, but there is a gap (looks like it's by design) in the radiator code on the Drivers side, and one of the AC pipes run through that to the condensor. Seems like a stupid idea to me. I'll try and get a pic up tonight of what i'm talking about :P
i have 32gtst and all i had to do was drop the stone tray on the bottom of the chassis undo top and bottom radiator hoses the 2 mounts on the top of the radiator that goes to the front support bar and unclip the bottom of the fan shroud so it clears the rad fan and it should lift out untouching the condensor pipe work as this usually runs in a groove in the rad core design
hope it helps some
Yeap, radiator comes out pretty easy, just remember to slide it and the fan shroud on at the same time when you put it back, if you bolt the rad in then attempt to put the shroud back on you'll have a hell of a time clearing the fan and not bashing up your rad.
thanks lads...I'll have a look at mine tonight, but to be honest i don't know what they've done. Pulling a radiator out should be a simple thing, but doesn't seem so here :confused: I'll get some some pics up 2 nite. thanks for your comments.
The best way to remove the radiator is undo the 4 x 10mm nuts holding the fan on....remove the fan. Undo the 2 x 10mm bolts holding the brackets that hold the top of the radiator. Undo the top and bottom radiator hose clamps and remove hose from radiator. Disconnect green plug from drivers side of fan shroud. Slide radiator out from the top. Should take no longer than 10 minutes.
gah i feel like a damn fool :rolleyes: there's something for the aircon sitting in front f the radiator, which is why there's a pipe going into it.
The raditator should be a piece of piss.
Thanks for all the help guys :)
Shit that's right, i forgot you need to unbolt the fan, that's what i was thinking of whne blathering about shroud and rad in one piece, need the fan in there too! :rolleyes:
GTSt's must be different to GTR's.........with GTR's there's no need to remove the fan. GTR's have a removable 'section' at the bottom of the fan shroud which unclips and once that's taken off the radiator can be lifted out with the shroud attached and it clears the fan.
My GTSt same as SteveL s GTR. 2 mounting bolts on top , drain water, remove one end of hoses, unplug wiring connector, lift out [ about 3 minutes. no removal of splash guard , fan, etc., etc. They must have kept changing their minds on the assembly line.
Takes longer to drain the water, than anything else.
I think you're getting confused with the air-con heat exchanger, it sits directly in front of the radiator and looks a lot like it, I killed my rad last weekand pulled it out (found that half of teh shroud that unclips down the bottom) and it really is a simple exercise to remove.
Now i need to find a replacement radiator, i'd rather a new one, but might have to settle for second hand.
yeah that's exactly what i was confusing it with :Oops:
At a glance it all looked like one part, i pulled my radiator out last week (unclipped the lower part of the shroud, removed the hoses and upper mounts) and had no hassles :cheers:
What's gone wrong with your radiator? leaking?
Rubber mount up top had perished, I accelerated hard, radiator fell on to the fan and crunch! On stuffed rad, called Nissan and they wanted $962 for a new one, I can't see much point in a 2nd hand one, so i rang around some more and found and aftermarket one for $359 which is far more reasonable. Gotta fix that mount too so it doesn't happen again.
Just went to pick it up and it was the wrong one, guy did some more ringing around and found the right one for $439, but there's a question makr over availability. Some Nissan diesel has the same top and bottom tanks but the core is too tall, might be able to make some Franken-Rad, just waiting for a call back.
Just thru a local radiator mob, Burton Radiators, pretty helpful so far but we'll see how it goes.
picked up my new r32 radiator last week for $352 brand new......the brand was KOYO i think.....looks the same as the nissan one, it works.
Yeah Koyo are supposed to be pretty much atleast as good as the originals.
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
