Hey guys and gals,
just wondering what materials ppl used for making the outer case of their CAI partition for their pod filters, and also what material was used for insulation?
I was thinking of aluminium sheets for the box, and those silver sun shades for the insulation (the type that have air pockets to insulate).
If people have better suggestions (especially for the insulation) , and places I can get these things (Bunnings is absolutely crap, as I can never find anything I want there), I would appreciate that.
Thanks
Zahos
https://www.sau.com.au/forums/topic/7477-cai-partition-materials/
Steve has hit the nail on the head.
Get your self some of that foam from Clarke Rubber.
For the metal stuff I used AluBond. Two 1mm sheets of aluminium seperated by 2-3mm of plastic/rubber. It has very good heat insulation properties.
But a single 3mm sheet of aluminium will work good too.
I found that mine did reduce the noise of the pod by about 30%. Your like me, I don't like it mega loud :D
  • 3 weeks later...
Hey ppl,
I'm still trying to find some aluminium sheeting, or alubond to make the partition with.......
I got the foil backed foam as meggala suggested, but I cant seem to find any1 that can help me with a rigid aluminium sheet....
I've been to several hardware stores, called several aluminuim places listed in the white pages, and no one can help me....
Is it just pure coincidence that I happened to ring all the knobs that cant help me, and completely missed all the ones that can????
Anyway, if someone could tell me where they got some from, it would be most appreciated.
Zahos
Originally posted by Zahos
Jay, what about the alubond stuff you mentioned. Where can I get that from?
I actually scabbed a bit from a mate.
They used the stuff to do office re-fits. The alubond stuff is used as the partitions between workstations !!!!
Tell you the truth, I have no idea where you can buy the stuff from :D
J
Originally posted by Henros
I have bought aluminium plates from Capral before. Their prices are not too bad, especially the offcuts.
Yeah, I'll get it cheaper anyhow....
A mate of mine is a cabinet maker, and buys aluminium from them for kickboards. He will get them through his company for me....
Thanks
Zahos
    • @GTSBoy yeah i know it was not the "great" idea but it is and option...but i think i will stay on no BoV rather then trying to make it work with "half" this and that. But that GReddy FV2 is cool...i like that you can make it like stock if you want (and have/make the custom pipes) For other thanks! it was alot of information. But for the sound...a dont rly "like" both of them...specialy if they are loud...but if i "must" choose i would rather have little whooosh rather than sutututu with no BoV....BUT that is what is i gonna get. So for the all info i gather. In my case:  No BoV is not that bad cuz it is stock...and iam used to put N/clutch right after rpms are around 1000 so it should be ok...just need to avoid "big" drops. But i do not have the engine in the car so i do not really know how "bad" or good it is. But as i had that little test drive it looked ok. The atmo BoV should be worse car would dump to much fuel specialy between the shifts...so without proper tune/ECU i dont want that. BUT with that...car should drive ok with no problems right? (i do like there is less piping wih this solution) 馃檪
    • Usually an RB20 won't stay in closed loop idle anyway. The O2 sensor gets too cold, stops swinging.
    • They aren't, but it depends on what interests you about an R32-R34. If it's the front engine I6 turbo that tunes well with a manual transmission an E92 335i 6MT is so incredibly cheap. You can get a super clean one for 20-25k USD tops. Put an LSD in it, tune it, have fun with it. If it's the general idea of AWD + turbo and a manual transmission the 996 Turbo is absolutely much more expensive, it's less practical but it's also basically a complete track-ready car from the factory. At least the Mezger doesn't have heaps of oil control issues. And in the US the 996 Turbo and R33 GTR are roughly the same price these days. 996 maybe a bit more now that the hype has abated for old Skylines here.
    • these are not the same
    • Best kept secret for seized bolts is crayons... Heat the sucker up with a torch, and push/melt crayon into it. Works a wonder. See if I can go 2 from 2 for you on how to get your bolts out...
