hi guys
got
Greddy/Trust Full Auto Timer Brand New in Box... $125 Delivered Anywhere in Aus
Apexi Pod Filter( Needs Adapter to Bolt up to your Car) Comes with 2 gaskets and 4 10mm bolts... $120 Posted anywhere in aus
JVC KD-LH3105 MP3 Player $300 VGC 2nd Hand C/W Box, Manual, CD, Loom, Remote Etc Etc. Guaranteed Working condition,4x50W, Flip Down Face..
Some Sort of Nissan Turbo With T3 Flange, Only Oil Cooled, NO SHAFT Play, VGC (Internal Wastegate) Was Told it was off VG30 Maybe Early 300zx Or Cima, The guy i brought it off said he Made 170KW's at the wheels with it on his CA18(Dont Quote Me tho) Has Home Made 3inch Dump Pipe to suit. Will Not Bolt up to your RB20DET with Standard Exhaust Manifold, Needs Spacer.. $ 350
Prices Are Pretty Well FIRM :P
Thats All i can think of for now... :ghost:
https://www.sau.com.au/forums/topic/74806-stuff-to-go/
    • Interesting....can't say I've ever checked it, have always just changed it in the off season as practice
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
