:flamed: This problem has me a little worried and confused... I just got my new car, R32 GTS-t (HOORAY!) and it is overheating :P , at first it wouldn't do it all the time, but now it does... its an 89' and has done 84000 k's. It doesnt feel down on power, doesn't blow smoke or have water coming from the exhaust, no coolant in oil, or bubbles in coolant. It will get really hot sometimes...which has me very concerned :warning: ... but then it will drop all of a sudden... which makes me think it is a f***ed thermostat. I know i shouldn't drive it, but i have to get to work, I get the car into speedworks on monday so they should diagnose the problem... hopefully. What do you guys reckon it could be?
Also, after the cooling issue is sorted of course, what do you guys reckon I should do to the car first? front mount, suspension, brakes... It already has an HKS pod and Kakimoto exhaust... the rest is stock... i think
Cheers
https://www.sau.com.au/forums/topic/74818-r32-cooling-issues/
you have beed air out? top of intake manifold on rb20/25
Is that the little screw with a yellow "never open when hot" label on the inlet manifold closest to the front end of the car? What do I do, just take it out and put it back in or do I have to run the engine with it off?
Dammit! Shes a still gettin hot. I took the bleed valve off last night, then went for a burn, it was good, then the heat just started to rise, so I limped home hoping it wouldnt get too hot. Thanks for your help anyway GDZ1LA :( Anyone else have any ideas.
Still I may not have done it right and GDZ1LA could be right. Any help welcome.
9.5 times out of 10, if you're not using water, of have none of the other symtoms you say you've checked, you have a partially blocked radiator core. To flush it properly, needs a bit of explanation. Needs to be "reverse flushed." Take it to radiator repairer. They have right equipment and shpuld'nt be very costly. If you MUST do it yourself, I'll [reluctantly] try to write a fair description.
This is all good news as far as im concerned... they are minor repair/replace jobs compared to replacing a head or gasket.. cheaper too. By all rights if I had a cracked head/ or gasket damage, i'd be experiencing a major lack of power right? as well as milky oil, possibly steamy, smokey exhaust yeh?
To do it right, reverse flushing in car takes a bit of explaining, so I thought, seeing it's so easy to remove radiator, why not do that, turn it upside down, and use as much water pressure as you can, from bottom to top, allowing the water to escape, alternatively, from the filler neck, and the top hose connection point. That would do a pretty good job.
Put the water hose in the bottom radiator hose point, and seal it as much as possible, so that all the pressutr water has to travel up through the core to get to top tank. This is the opposite direction of flow to when radiator is in car, which is why it is more effective in removing blockages than flushing top to bottom.
ahHHhhh HUH!! mine is doing that as well! the temp gauge is reading just a bit above half, is this actualli normal/acceptable? it never rises above this point and isnt using any water, even after lots of hard driving, so would this be just a partially blocked radiator i presume?
just dont like looking at it so high , when my bro's R32 is reading below half!
thanks for any advice guys.
ps- josh what colour if your 32? seems like there is quite a R32 "population" explosion in perth ;) mines black coupe, and black sedan for my bro.
