Just as reference
http://babelfish.altavista.com/babelfish/t...rod%2fprod2.htm
Anyway,
i read somewhere about just pulling a plug or something, but i just want to think about this in a single thread.
I want to know if anyone has any evidence for HOW it could possibly damage the car, i mean, if there is a controller made for this kinda change im sure that company wouldnt want to hold that much responsibility. Also, someone mentioned the r32, hasnt teh atessa system basically stayed the same.
Reason i ask, when i get a stagea(hopefully in a few weeks now) i am going to want to slide it (yes, LSD, coilovers etc would be bought) and i dont really wannt eat gear boxes.
Also, what about after a manual conversion, or an S, anyone know the effects.
Yeh, so, basically just looking to make a single thread on the idea. Cheers peoples
https://www.sau.com.au/forums/topic/74841-changing-from-awd-to-rwd/
Yeah theres a couple of RWD Stagea series 2 up in Queensland - Motorman Imports I think (they want a bit much for them though I reckon) - get one of them for drifting - then u dont have all the 4WD weight to the car either. Or even better I am sure you could even find a manual RWD Stagea in Japan and bring it over. Drifting a skyline... gonna be a sight to see - take some photos :wassup:
But if youve already got an auto RSFour lined up - then theres heaps of technical stuff in the non-Stagea threads about disabling the front wheel drive and arguments over potential damage - do a search :)
:D
R32GTR's do not retain hydraulic pressure in the ATTESSA system when the fuse is removed. R33/34GTR's do have residual pressure, so you can't just pull the fuse (or turn it off with a switch). Stage S1 is the basically same ATTESSA system as R33 and Stagea S2 is the same as R34. So you can't just pull the fuse (or turn it off with a switch).
This is one reason why R32GTR's tolerate a larger rear end slip angle (oversteer) then R33/34. Since there is residual pressure, the response time for 4wd is much reduced.
I can speak from 4wd dyno experience, the only way to ensure 100% 2wd from a Stagea at all times is to remove the front driveshaft.
:D
SK,
Where is the Attessa ecu in the Stage? Also, by "pulling the plug" and removing front shafts (how i dyno'ed my GTR) is it known if this will effect the car over time? wear/tear/damage etc? I'd like to convert mine to RWD when I do the manual conv.
Thanks mate.
Christian
SK,
Thanks mate.
Christian
hey prank the attessa ecu is behind the passenger side rear quarter panel above the rear wheel, its a bitch of a thing to get to and requires removal of rear trims and shit, which are all on clips soo be careful, dont wanna snap any of em :uh-huh: mines in rwd only by totally removing the attessa hydraulic line from rear of box and putting a stop on it, which stops pressure in the transfer case and therefore shouldnt be causing any damage (i hope) :confused:
sk would know more..
cheers
Brad
Did you remove your front shafts too?
Thanks for the info too.
Christian
front driveshafts and front tailshaft are both still on, but the attessa clutches have no hydraulic pressure to activate front wheels so its impossible for them to work.. ive done plenty of burnouts in 2wd and donuts, so i know its 2wd for sure :uh-huh:
hmmm, very interesting, so switching to RWD may be as simple as blocking that hydraulic line from the rear of the ecu???
Thanks heaps for the info
Christian
the hydraulic line comes off the very rear of the gearbox (well transfercase) if u check under your auto is exactly the same and its a huge thick line which runs to pump above rear diff. the attessa clutches are pressed exactly like a clutch setup, with the fluid pushing a piston in the rear of the transfercase, which pivots a arm in the box to squeeze the clutch packs together activating 4wd... the only ecu involvement is deciding when to turn pump on and off and to activate the active lsd which is very similair style diff setup with clutches inside and done with same fluid.
hopefully thats right... cheers
Brad
ok, so do i block it from above the diff? or from the ecu?
Thanks man, so clueless with this stuff.
Christian
no worries mate i didnt have a clue until we pulled the entire transfer case to bits to check the clutches and then we realised how simple it worked, and to block it off we undid the line off the rear of the transfer case and i have a spare plunger thing from the auto tranfer case so we screwed it into that instead and then made a bracket over the top of the plunger so it couldnt push at all and we just wired it up under the car for ther moment until we sort out y its staying in constant 4wd with it hooked up... im really chasin a stagea wiring diagram for the attessa system has anyone online got one????
cheers
Brad
Hi all,
I'm only new to the forum, & looking @ buying a stagea at the end of the year.
Would it be possible to fit a electrical valve in the line so you could have 2wd at the flick of a switch, of is there to little room under there?
Hi all,
nope because they fluid builds up pressure in the line and pushes the pin in the transfer case to activate 4wd and then u try and block the hydraulic line will still mean there is pressure on the transfer case, it needs a hydraulic switch but needs to bleed itself when activating 2wd to release the pressure as sk mentioned above that happens on 33 and 34 gtr's.
hope that helps
Brad
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
