i have just purchased this mainfold, i relise its for twin td 05 / 06 turbos, but i cannot afford these,
what oem style turbos would suit this manifold, it has 3 bolt flanges for turbines,
subaru td turbos may work but there 3 bolt flange has a bolt offset,
Mitsubishi Pajero diesel turbos non gate ones) have the proper 3 bolt flange could these housings adapt to another turbo easily?
any more suggestions? twin 16v rb20's? vg30's? (changeing flange)
they need to support 750hp, this will justify the laggy t88
***EDIT R31Nismoid***
If you want to sell them, post them in For Sale
Otherwise questions only here. Thanks
Hey man - why not have a look at a pair of TD04s? AFAIK they are the same flange pattern as TD05s and they are a dime a dozen here in New Zealand because of people with GSR Lancers upgrading from them to TD05s or bigger. A pair of TD04s leaned on should be able to make around 300awkw and should be pretty tractable as well.
Trust turbos are made by Mitsubishi, maybe check around for some Evo turbos. I use the gaskets as the checking template, cheaper than buy a turbo and finding it doesn't fit and easier to carry around than a manifold.
You can't use a diesel turbo, they don't hand the much higher exhaust gas temperatures from a petrol engine.
:D
