Personally I would much rather have the superior performance of a low mount
What is the superior performance? Is it just centre of gravity as you mentioned earlier? Please elaborate on why low mount is superior.
Personally I perfer high mount because most low mounts act like ovens to the turbo. Look at most low mount setups and the compressor housing is very very close to the ex manifold making it difficult to protect from heat using even the best insulation. This is very much overcome in the high mount manifolds I have designed and many available made by others. You can argue that heat travels upwards, but really it needs matter (ie air) to travel through and with low mounts heat stays to close to the compressor housing. I have transitioned from low --> high mount and I high mount ran cooler. The advantage also is that you can guide the heat from the exhaust manifold away from the compressor and also insulate your manifold to keep heat within the manifold (which you can also do with low mount ofcourse). I see that its all about heat bt the two setups. Chances are differences are minimal and so it comes down to personal preference. Only advantage as sydney kid said before is centre of gravity.
Cheers
We tried a GT30 on the R34GTT mounted to the standard  manifold using an adaptor.  It fitted in easily.  If I remember rightly, Steve on here also had the same on an R33GTST making 300+rwkw.  The HPI R34GTT had a GT3040 low mounted on a Croydon's custom exhaust manifold, around 310 rwkw if I recall correctly.:rofl:
Hi Sydney Kid,
Just interested in how the r34 was to drive with the GT30 - did it lose responce in the important 5th gear 100km/hr zone?
How tidy was the install? Did all the standard heat shields fit ok?
Cheers!
Hi Sydney Kid,
Cheers!
It was an OK install, the exhaust manifold heat shielding fitted OK, with a little mods. You could barely tell that it wasn't standard, the dump was a bit obvious.
It was not my kind of turbo installation, too laggy, nothing--nothing---nothing--then hang on, throttle response made driving fast very tricky, the handling was compromised by the lack of throttle control. The useable power band was too small as well. It had 40 rwkw more but it is was slower in most applications.
It lasted a month and I ditched it, the GCG ball bearing hi flow was a much better all round package. That's for my taste and driving requirements, some other people loved the big turbo feel.
:rofl:
:P
Good to know SK,
I'm getting to the stage where I'm looking at a better turbo than standard - just don't want to go too small as I'm also looking at doing an rb30 bottom end......
I very much like the idea of being able to bolt the GCG straight on and it looks the same.
From what I've heard I might be happy enough with a GCG, tomei pon cams and a good tune.
Cheers
thanks elu!
low-mount is stealth, generally thats a good reason... you have your gate sticking up in the air for all too see...
For me that wouldnt work. may aswell high mount it as you know whats lurking there.
that personal opinion though :P
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
