Quote From manufacturers ad
I have spoken to a manufacturer who will be releasing their RB26 Manifolds shortly and with RRP set at $1299 is it definitely a viable and cheaper option compared to HKS headers.
General description:
Complete stainless steel (3mm thick!), mandrel bent and equal length headers/turbo extractors. Minimum gain we have seen is 12% (At the wheels) on a dead stock R32 GTR. These are a complete bolt on for all RB26 Engines and also have fittings for the factory heat shield.
Firstly these headers are brand new and construction is from mandrel bent stainless steel. Other popular brands have mild steel flanges that have been "chromed" (or Painted) giving it the stainless look but not the associated benefits. The difference in flanges is the stainless steel will aid in gasket life and reliability with pipes and flanges expanding at the same rate. I know I personally don't want to be changing gaskets in 6 to 12months time, this is an evident property of mild steel flanges mixed with SS pipes as they expand and contract at different rates, which eventually causes them to warp! Ours are constructed of the same grade Stainless steel so they won't do this- ever!
Mandrel bent pipe work in 3mm stainless and direct bolt on for all RB26 engines. We have also included a provision for the factory heat shield to keep under bonnet temp down. In addition, these can also be heat wrapped or HPC coated for further improvements
Included are:
-Headers (For 1 engine)
-Manifold to head gaskets
-Turbo Gasket
Bends and welds are kept to a minimum to improve exhaust velocity and pipe length is made as even as possible (equal length). With these fitted you will see a power increase from around 1800 RPM all the way to 8000 RPM (not all Rb26's rev to 8,000) providing a broad power range. This makes every day driving a lot more enjoyable especially for those of you who are running aftermarket turbo's. The car is really that much better to drive! With a stock turbo, the power/torque drop off above 6500 isn't as bad and boost comes on a little earlier providing stronger mid range torque that hits like a bomb. The top end power increase is due to 2 reasons. Firstly; boost doesn't drop off like the factory manifold does. Secondly; the efficiency and flow is improved at high rpm driving- this was optimized for people using turbo upgrades such as garrett and HKS turbo's. In Addition the collector flange has been closer match ported. If you have a look at the factory manifolds you will notice a fairly large step where the manifold mates to the turbo's. We have changed this to a smooth entry. Perfect for street/track cars.
In addition to this they also have a sound change which is inevitable with the velocity increase in the exhaust. The exhaust does sound tougher (higher pitched roar) with these fitted. Expect around 27 hp (at the wheels) on a stock RB26. Bigger gains have been seen with more modifications/better quality parts fitted but due to so many variables, the gains have been from 37 rwhp (about 20%) to a whopping 69 rw hp on a severely restricted car (This car had all the bolt on goodies and ended up making just over 500 hp (at all 4 wheels). This makes for a cost effective power increase!
This doesn't just add top end power but increases overall power and power under the graph making your car overall quicker in a variety of situations including out of corners, partial throttle, up steep hills etc. Its easy to make something that improves power, but improving power over the entire useable RPM range and partial throttle is not so easy. Not only this, we have seen full boost reached 400 rpm earlier on a stock car and nearly 950 RPM on a more modified car. This makes a massive difference to the fun factor especially on the street and accelerating out of the corners. Unfortunately the dyno graph doesn't show partial throttle improvements in response, drivability and off boost torque. We will post dyno graphs shortly. This will fit your stock turbo or another bolt on.
Group buy price for 10 $849 + Shipping $30 nation wide via courier
If it hits 15 or more I need to update this with a specific price.
Group buy closes 26/6/05 and firm payments are needed before this date and your name is put down.
They will be delivered approx 18 working days after that!
There is no pick up available and all items are shipped via courier
They are not available for any other skyline!
I will try and answer any of your questions, however feel free to email [email protected] if you have any questions I can not answer
https://www.sau.com.au/forums/topic/74935-rb26-pre-turbo-extractors/
Yes!
But they were for the 1st generation.
These have been revised since then.
-Heavily polished
-pipe work is redesigned for better flow
-Machined and polished flanges
-better quality welds
-modifed JIG for easier fitment
-Additional bracing
Edit: Was just told about more details
The pics look very much like the ones I saw a few weeks back but the workmanship does look very good.
amosite... have you actually seen one of these and had a close up look.
do you know where these are made?
I'd like a set without the posts for the heat shields.
And yes very interested unless I pick up a set before hand
Yes, I have seen these in person!
I have also seen them in comparison to the 1st gen and some of the cheap chinese shit going around! You get what you pay for in the latter.
These are made in the land of the rising sun!
Im definitly in on this batch.
I asked him about the posts and they are for heat sheilds. I wasnt too keen on running them after fitting them but it is vital otherwise the intercooler pipes suffer heat soak as they sit just above the manifolds.
I still want them without the posts!!!
Can they get them this way?
They should even be cheaper !!!!!(6 less welds)
what diameter is the pipe on these manifolds? can they be done in a larger diameter pipe
They are 42mm each. You wouldn want them any bigger as they start to induce lag and are only really a benifit if your going to be running more then 950 hp and 12,000 rpm.
Who makes these? What grade stainless? Have they been flow tested, and if so, what were the results?
Cheers,
Lucien.
[email protected] makes them
304 Stainless
They havent been flow tested. I believe that flow bench data has very little to do with performance on exhaust manifolds. Dyno and on road testing is more useful as exhaust heat has a major impact on outright flow.
I bought a pair from Roguepi off ebay, One had large loose dags inside which broke off easily. All surfaces had to be faced as they were massively warped($160) and I paid him for overnight delivery which took almost 2 weeks...and he is also in sydney. Quality is quite good on first inspection but looking deep inside there are(were the 3 pipes meet near the turbo flange) large lumpy flow reducing welds. They are quite cheap but still required alot of work to bring up to scratch. The Turbo flange is also a larger size to stock turbos and HKS 2530's etc which require's maching of the exhuat housing to match. Look at the pic's and then at your turbine inlet see what i mean. Oh and the heat shield bolts don't come close to lining up. All I can say is physically check before you buy.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
