i am shocked i wake up to
scott come here scott my mum Yelling at me its like 11
she was outside with a white Gts-t Skyline r33 outside i am like wtf is going on
I go out she shows me the car and says she found it at a dealer down the road i am Shocked for a Dealer in my shit town to have a import next i look at the price on the window thinking it will be heaps
$16999 i am shocked
Look over the car looks clean nice white body kit mags's 17's
120000ks
inside is a little worn hand brake and gear boot
it was imported in 2002
i get him to pop the hood
I find a
Big pod
Brand name front month intercooler
Turbosmart Bov
look at the exhaust and under the car
has 3" turbo back exhaust that isn't too loud which is just what i wanted
i see aftermarket Shocks and springs
Look at it i think its a M spec with bigger front brakes and LSD due to the wing caust its a 1994 with a big wing
anyway bak to my story i go inside and mum goes back to the dealer
i thing about it and go y not have a go i ring her tell him i will give him $15000
i wanting for a nah thats not right off him
he takes my offer of 15k and tells me it is off the market till i pay up gave me a week
I get 3 months warranty
i went to the bank later that day and i am buying it he has taken it off the lot i am still shocked
what r ya thoughts did i get a deal or what
from a dealer yes that is cheap, althouugh you are mistaken about a few things,
all 33 gtsts have the same brakes and LSD not just mspec.
just make sure its in good nick body and mechanically get a compression test done get someone that knows skylines to check it out it might be a rough car and u might not see it unless u know what to look for.
i know a bit about skyline and it looks fine to me
yes the day i get it i am taking to my Import mod shop that only works on Imports and they will check it over
Body is pretty good only thing is the seals on the windows and shit r going but my silvia was the same
What what All r33 have LSD do they i thought it was only M specs
yeah windscreen and rear window seals are often shit
probably best to take it to your import shop for inspection before u buy it rather than finding out any bad news (if there is any) after u get it.
all r33 gtsts have LSDs and the same brakes for sure, i have inspected about a million of them for friends buying and have had 2 myself :D
nice find man, atleast your mum knows what a skyline is, she mistook my GTR for my bro's 180sx driving down the st.
mark
:D Thats gotta hurt.
I reckon 15k from a dealer is an awesome price... gotta wonder how much he paid... :headspin:
just a question like 2 or 3  ppl said get a compression test done is this a thing thats notorious for all skylines or just the 33?? how can u tell if it needs a compression test done or if it has a lack of compression?
compression testing will show if there is something wrong with the engine, like damage or excessive wear, if a compression test comes out bad its best to do a leakdown test which will show exactly where the problem is.
any car you buy should have a compression test done for peace of mind. especially if its a turbo or hi performance car.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
