Limited Edition Monte Carlo. Top of the range VR4. Has all the evo bits from factory.
Metallic Black in colour
Fully optioned(inc sunroof and rs bonnet vents)
Factory: evo twin piston calipers
4 bolt LSD
3.9 evo gear ratio
evo 2 size cooler
oil cooler
515 cc injectors
stock motor 250HP
Mods: GAB struts and springs(front camber top, stiffness adjustment)
cold air intake
3" turbo back exhaust with custom twin dump pipe
Daikin Exedy 5 puck brass button installed 7K kms ago.
Turbosmart boost controller(8psi and 16 psi)
Others: Carstart Alarm
tinted windows
Big aftermarket front bar
17" 6 spoke lightweight Rays Engineering wheels (gold)
front strut bar
Aftermarket polyurethane bushes
Want to keep up with Evos and STIs at a budget with all the luxuries?!
Will do low 13s. Has done 13.5
Price: $12,900 with Microtech and $12,500 without
http://www.clubvr4.org/photos/vr4pwr1.jpg
http://www.clubvr4.org/photos/vr4pwr2.jpg
http://www.clubvr4.org/photos/vr4pwr3.jpg
http://www.clubvr4.org/photos/vr4pwr4.jpg
http://www.clubvr4.org/photos/calder_03_12_3_035b3.jpg
https://www.sau.com.au/forums/topic/74942-89-mitsubishi-monte-carlo-vr4-fs/
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
    • Haha, the big brain move is to buy a second set of headlights to clean up or retrofit. I definitely don't have one sitting in a cupboard that hasn't been touched since it arrived. Just have to ignore the intrusive thoughts that suggest the second set is not quite as good as it could be and to buy a third set that the job would definitely get done with
    • Nah I'm talking about the GTS-t with 15" wheels and single piston brakes.  I've seen them pop up occasionally over the years. You can see it in the brochures. Most were early models (aka Series 1).
