g'day
i have a question about "dyno dynamics" dyno's and their settings...
i have seen that the intake temp is the main setting that seems to vary from graph to graph when different people put their power figures up
so my question is...
what would the power difference be for a car run with an intake temp of 14deg versus an intake temp of 30deg on the settings? (assuming everything else is constant...)
would this be significant, or just a couple of killowatts?
obviously its not an issue, i was just thinking...
(its almost exam time so i have plenty of time on my hands and will do anything to procrastinate!)
cheers,
Warren.
https://www.sau.com.au/forums/topic/74943-dyno-settings-query/
Shoot Out Mode (SOM) compensates for temperature differences. So a guy in Tasmania in winter should get the same power if he was in Cairns in summer.
The old rule used to be 5% change in power for every 8 degrees change in temperature. I have no idea what DD apply for SOM correction.:P
it makes a difference on a turbo car is the sensor is in the engine bay as the sensor see's...
eg: 50 degrees due to a pod and no CAI... but then it goes through an I/C on a turbo car so the car is actually seeing a different temp and shootout is applying a correction that isnt quite correct.
Its different for an N/A car.
I've seen a 10-15rwkw difference in my car using shootout with the sensor inside, and outside the engine bay.
reason i asked is that when i got my car dynoed it was about 15deg outside, and the temp was measured at the intake manifold, so the real temp getting to the cylinders
but on dyno days i see them placed at the air filter and temps of 30deg
so let me rephrase my question...
- dyno in shootout mode
- car in same workshop, same day, same time of day
- car gets power measured with IT set to 15
- then car gets power measured with TI set to 30
same figure?
same figure?
Use the 8 degrees = 5% rule of thumb.
Need more info though....
1. What is the ambient temperature (AT)?
2. What is the rwkw reading at the 15 degrees Inlet Temperature (IT)
Interesting question this, was trying to apply this theory to two.60l's thread where she made 466 rwkws in shoutout (8) mode, but when asked to provide a graph in non shootout mode the reply was "there's no difference".. WTF??
Anyway as an example my car made 335rwkws (Racepace dyno dynamics), and then backed up with 360rwkws in shootout mode!!!!
Haven't got a printout of the 360rwkw (shootout mode) run, so sorry can't compare temp readings...
Although next week i'm getting poncams installed and a retune so I'll get Ben to do a run in shootout mode aswell as normal mode... STAY TUNED!!!
That could be true, if the Ambient Temperature and the Inlet Temperature are at the temperature that DD have selected as their "reference temperature".
That's normal, and precisely what I would expect if the Ambient and Inlet Temps are hotter than the "reference temperature". It is exactly the same as dynoing your car in summer (335 rwkw) and then again in winter (360 rwkw).
That should be interesting:cheers:
:rofl:
1. the ambient temp was about 15deg
2. the car made 132rwkw at 14deg inlet temp
if its 15deg outside, even with a FMIC surely i could not be seeing 15deg at the inlet manifold? would have thought realistically the inlet air would have been about 20deg
but if i were at a dyno day instead of having booked tine on the dyno the probe would be elsewhere and definately not measuring 14deg... maybe the probe wasn't even hooked up? and it was jsut set at 14deg?
hmmmm
hmmmm
Thats the problem with dyno days sometimes they dont take the time to set the cars up properly as it takes longer between runs.
But unless the all the sensors are in the correct positions ect. the results mean nothing.
Example
Ice performance Dyno 195 rwkw
All sensors in correct positions ect. 22 deg day in shootout mode.
Local Dyno comp 156rwkw
no sensors in airbox, no fans infront of the cars, 40 deg day, no shootout mode
car ran great no pinging at all.
Shoot out has some pretty generous enertia values (esp shoot 8), hence the higher numbers. Intake temp is also corrected back to 20C, so placing the sensor in behind the rad will give a substantial 'improvement ' also.
We like to use ambient air for Intake temp and 0 enertia. When done in this manner, the cars perform as per the hp calculators. When using shoot numbers, the cars underperform........
That's the answer I was looking for!!!!!!!!!!!!!
Hence some dyno figures getting around which are truly over the norm....
The difference explained to me by a DD rep quite a while ago:
Inlet Temp - Ambient Temp / 5 = x% difference.
Ex : It's a 25 degree day and the probe is placed in the engine bay and reading 55 degrees.
55-25/5 = 6% will be added to the measured power in shootout mode.
Isn't that only half the story? That's the correction for Inlet Temp being above Ambient Temp, but what about Ambient Temp being above DD's reference temp? Based on RPMGTR's post wouldn't it apply additional correction for the Ambient Temp being 25 degrees compared to DD's reference temp of 20 degrees?
Keep in mind Shoot Out Mode doesn't always ADD to the power readings. If the Ambient and Inlet Temps are less than DD's reference temp then it will show LESS power.
:P
Agree with you...
The point i was making, is the discrepancy on where the temp probe is placed and the effect it has on the readings.
There was a dyno sheet where the IT was 82 degrees, a while back.
true...
i remember seeing a thread comparing optimx to bp ultimate
ultimte made about 10 more rwkw, but also had an IT 10-15deg higher than the optimax reading...
hmmmmmm... bit sus to me
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
