Turbo Kit suit RB20/25,
Turbo Kit Consists Of:
A Percision T04e, (with a T/3 Flange,)
Turbo Bag
40mm Waste Gate,
Braiden lines,
Gaskets, Bolts, Chrome fittings and V-Band fitting
Also includes Hks Pod Filter.
This turbo package is capable of making 300rwkw on only 14 psi. The turbo have steel front and back wheels and are brand new are rated at 550hp. it is also 360 thrust bearing The package comes with all of the necessary fittings to make it an easy fit to any car, there is no manifold included, was bought from this forum and never put on, now selling and using cash for other investment.
It is NOT a XSpower or Masterpower turbo, I can also refer you to someone who sells Highmount manifolds. if you do not decide to weld the wastegate to the rear housing or factory manifold
PRICE DROP $800 FIRM NEED TO SELL ASAP
PM or call 0400261099
https://www.sau.com.au/forums/topic/74946-turbo-kit-suit-rb2025/
what r LOP Rs?
is it water cooled?
is it ball bearing or plain bearing?
what are the a/r ratio's?
cheers
L.P.O is " local post office" Rs, is "Regards"
It is only oil cooled and 360 thrust bearing
front is .60 and rear is .82
Rs,
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I though you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
