it will only cost you more in tyres if you fry them, but at least the wear will be even, so instead of changing one side more often than the other, you will be changing them at the same time.
Honestly, the difference between mech and viscous is huge.
I found that I could get off the mark without spinning my wheels, where as before anything more than a very gentle launch would result in wheels squeeling as I left the lights. This of itself is pretty important with todays hoon laws but also makes it more enjoyable to drive.
Also, when the wheels do spin, the back end is alot more predictable (even better if you lock the hicas). Going around corners/bends if you put your foot in, the back end doesnt launch sideways unpredictably, and coming back it doesnt whip around. It will still step out, but it is much more controllable and you can just keep your foot in, hold it sideways (if you want) and bring it back under control. So much better, once you upgrade to mechanical you just wont want to go back.
That is of course unless you use the car for cruise/shopping trolley duties only.
If you go back to viscous, you will kick yourself.
Would have to agree with Steve there, once the back end steps out with a mechanical LSD it is so much easier to control. you can hold ya foot flat and goes were you want, instead of everywere else
Im sure having a lock bar on mine has made it just that little bit better aswell
And you get way better launches
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
